Page 345 of 450 FirstFirst ... 245295335340341342343344345346347348349350355395445 ... LastLast
Results 5,161 to 5,175 of 6745
  1. #5161
    Quote Originally Posted by trinicolin View Post
    Hi Pros. I have a W204 EIS that is unable to read via OBD but can read via IR. Do I have to replace EIS or can it be repaired?
    Sent from my SM-G930F using Tapatalk
    If you are sure the problem is from the EIS, its better to replace it. goodluck
  2. The Following User Says Thank You to ahmadiga For This Useful Post:
    trinicolin (20th September, 2018)
  3. #5162
    Apr 2014
    Quote Originally Posted by ahmadiga View Post
    New or used?
  4. #5163
    new and the used they all work the same, the difference is used one you must renew it and before you do that must get the password. new one u don't need renew
  5. The Following User Says Thank You to ahmadiga For This Useful Post:
  6. #5164
    Mercedes W164 All Keys Lost
    Hello DK Friends, i have a mercedes all keys lost vvdi can read the eis when i connect the car central gateway, and when i attempt for data aquisition an error appear that no connection with the OBD even when i tried the IR for the lost key. anyone who done thiscar before? i attach the error message screenshot.
    Thanks in advance
  7. #5165
    Apr 2014
    I am trying a used one. Got the password and renew. Can I use Xhorse ESL emulator then adapt to car?
  8. #5166
    sure, you can
  9. #5167
    Oct 2012
    London
    Thanks in advance
    W164 2006-2008 not supported NEC EIS
  10. #5168
    nickolasd's Avatar
    Nov 2015
    now i got my 200 bonus points for using xhorse key but how do i exchange it for tokens? where its been done?
    Quote Originally Posted by Maartinj View Post
    simple make one Xhorse mercedes Key - and you get 200 points, 200 points = 1 token
    you can get points from keys before you program it .
  11. #5169
    Pair your vvdimb and vvdikey tool and with ios or android app you can exchenge points
  12. #5170
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by Brat View Post
    no need vvdi key tool
    many thanks to friend kevfield
  13. The Following 2 Users Say Thank You to daxxer For This Useful Post:
    comizelu (25th September, 2018), rojhat (25th September, 2018)
  14. #5171
    Aug 2018
    Hi,dear all, i want to vvdi mb can support FBS4 after update? thanks in advance.
  15. #5172
    Moderator
    PremierD's Avatar
    Jun 2009
    NO ......................
  16. The Following User Says Thank You to PremierD For This Useful Post:
    LISA100 (28th September, 2018)
  17. #5173
    Maartinj's Avatar
    Nov 2010
    Contact Xhorse Technical Support
    or
    link :
    http://www.xhorse.uk/issue/
    From now you can contact Xhorse technical support and complain what is not work / issue with device you have.
    Simple write all necessarily information and update pictures / log , and one of Xhorse tech support will contact you.
    Please DONT USE THIS LINK to ask tech support "how to do.... or where to click to do ...." activations, prices etc
    Please write your issue short and sweet.
  18. The Following 3 Users Say Thank You to Maartinj For This Useful Post:
    bluesky2010 (6th October, 2018), obeids (28th September, 2018), vasa (28th September, 2018)
  19. #5174
    May 2013
    Quote Originally Posted by khalilo_de View Post
    If you have original key from car read nec key mcu then you got original password
    Then you calculate pass for donor eis with all key lost to renew it
    After you can write old eis data on the new used eis with original key pass
    Envoyé de mon SM-G930F en utilisant Tapatalk
    This key is BGA and not NEC............
  20. #5175
    Mar 2014
    north east of Africa
    HI its my first 207 diagnose with a steering lock mechanical malfunction.
    pull the hole steering Coulomb then cut the lock bolt .Lock connected to the EIS on table start
    working again . I need advice on what to do , I have VVDI MB emulator and also I can change the
    motor of the ELV but the new motor is Chinese manufacture I got it a year a go ..
    THANK, U
