Page 349 of 450 FirstFirst ... 249299339344345346347348349350351352353354359399449 ... LastLast
Results 5,221 to 5,235 of 6745
  1. #5221
    auto techniek's Avatar
    Mar 2017
    Quote Originally Posted by ficho View Post
    Yes, this can be done, just depends if the tool you want to use supports this feature.
    I m talking about vvdi MB tool.
  2. #5222
    Feb 2014
    Quote Originally Posted by auto techniek View Post
    Of course - it is one of the first cars supported by VVDI for AKL jobs.
    All is done by OBD and IR - you need internet, some tokens and a bit of patience.
  3. The Following User Says Thank You to autoTkey For This Useful Post:
    auto techniek (10th October, 2018)
  4. #5223
    HI,
    Nowhere was stated that you where refering to vvdi MB tool, as I know many tools out there on the market do support the W212 AKL via IR only.
  5. #5224
    Mar 2017
    Eis removal W639 from 2005. Is it easy tot do?
  6. #5225
    newone's Avatar
    Oct 2016
    https://www.youtube.com/watch?v=QMeVlGRhIN4
  7. The Following 2 Users Say Thank You to newone For This Useful Post:
    auto techniek (11th October, 2018), Levanime (9th November, 2018)
  8. #5226
    drugowaz's Avatar
    Mar 2015
    Lithuania
    For uk always much easier .
  9. #5227
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    1 min job
    many thanks to friend kevfield
  10. The Following User Says Thank You to daxxer For This Useful Post:
  11. #5228
    Mar 2013
    Europe
    W639 remove EIS ---> i remove Radio and than EIS from from Radio place
  12. #5229
    Apr 2014
    Hi guys, I am working on a w211 where the key won't turn in the EIS. Checked the key with VVDI MB and it is reading. Further checked the and found that there isn't voltage on the big connector of the EIS also the ESL. There is voltage on the small blue connector of the EIS. Fuse F029 is good. At this point I need a wiring diagram to do further checks. Can you all assist?
    Sent from my SM-G930F using Tapatalk
  13. #5230
    Nov 2016
    Hello , I am trying to read W218 Eis for all key lost but I can't .. Vvdi say me " failed:00 ".
    Nobody know if it is possible the data reading and new key with Vvdi Mb Tool ?
    Thanks!
  14. #5231
    Mar 2016
    Quote Originally Posted by Gioaute View Post
    Thanks!
    fbs4 not possible
  15. #5232
    Will be good if can xhorse developer solved bag's in BE key for st-209 and st-211 ezs ?
    ezs acceppt 6-7 time key, and stop to work.
  16. #5233
    Nov 2016
    Quote Originally Posted by alexxxb0450 View Post
    fbs4 not possible
    I am disappointed .. other cheaper tool as CGDI can read FBS4 and Vvdi not !
  17. #5234
    Nov 2016
    Lol..........
  18. #5235
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    then buy other tool and dont disturb here
    i think you are sure many happy after you buy other tool
