Page 272 of 450 FirstFirst ... 172222262267268269270271272273274275276277282322372 ... LastLast
Results 4,066 to 4,080 of 6745
  1. #4066
    Sep 2015
    help me please w203 2003. Need to make a key. IR will not give me a pass. Thanks
  2. #4067
    Romania
    DD1: It has NEC mcu inside the EIS, it means that you cannot read out by soldering wires inside the EIS.
    What is the problem with the IR reading?
    Can you send pictures from the error message?
  3. #4068
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by leson View Post
    help me please w203 2003. Need to make a key. IR won't give me a pass. thank
    omg omg omg
    many thanks to friend kevfield
  4. #4069
    dd1's Avatar
    Aug 2014
    giúp tôi xin vui lòng w203 2003. Cần phải thực hiện một chìa khóa. IR sẽ không cho tôi một pass. cảm tạ
    English, write it in english
  5. #4070
    dd1's Avatar
    Aug 2014
    Quote Originally Posted by tferenc View Post
    I read it obd2, but IR won't read it. I will try it again and post the error picture here
  6. #4071
    Quote Originally Posted by dd1 View Post
    for AKL you need to read it through IR.
    and you also need a gateway or the power adapter.
  7. #4072
    dd1's Avatar
    Aug 2014
    All the reading was done on the car, everything connected. Only thing missing was the key. Which I want to make. Thnx
  8. #4073
    try remove the ezs from car and do it on bench.
  9. #4074
    dd1's Avatar
    Aug 2014
    Will the vvdi2mb work on the bench with this Eis???? Or I have to use a programmer to read the Eis?
  10. #4075
    dd1's Avatar
    Aug 2014
    If it is a bench prog, can you give me the pinout for it? Thnx in advance
  11. #4076
    Sep 2016
    Take out EIS and read EEPROM with programmer. This method will give you pass
    Plenty of diagrams on the forum...hint "use the search function"
  12. #4077
    Romania
    Just search on google for w164 eis pinout:
    https://www.google.ro/search?q=w164+...z35EtV5tnlULM:
  13. #4078
    khalilo_de's Avatar
    Could so here introduce me how to renew esl w906 with nec mcu
    Envoyé de mon SM-G955F en utilisant Tapatalk
  14. #4079
    khalilo_de's Avatar
    Quote Originally Posted by khalilo_de View Post
    Pb solved
    Connect kline and power to esl plug then read esl data and make it renew very easy
  15. #4080
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Pb solved
    Very Nice
  16. The Following User Says Thank You to daxxer For This Useful Post:
    khalilo_de (11th December, 2017)
