Page 275 of 450 FirstFirst ... 175225265270271272273274275276277278279280285325375 ... LastLast
Results 4,111 to 4,125 of 6745
  1. #4111
    drugowaz's Avatar
    Mar 2015
    Lithuania
    You will not read pass it non IR non obd i tried w210 w208
    Only remove mcu
  2. #4112
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by gilahish View Post
    Hi, tried to make a cable in order to try to read w202 / w210 without taking hc05 out, i used some diagrams i found but it didnt work. i think i just cant figure out connections from obd to eis. can someone help me with that?
    obd - pin 1 k-line, 4+5 ground and 16 12v.
    eis connection - ground, 12v and kline
    i made these connections but wont get it to work.
    Attachment 493214Attachment 493215
    this ezs work reading obd, but......you must did some steps to get it success...
    without wakeup ezs you cant read nothing
    many thanks to friend kevfield
  3. The Following User Says Thank You to daxxer For This Useful Post:
    gilahish (16th December, 2017)
  4. #4113
    Jan 2017
    Quote Originally Posted by daxxer View Post
    You mean when ezs connected to car? Or on bench?.. if so how can i do it?
  5. #4114
    Vvdi not work read pass with k-line 210,202,208.... !!!!
    i hope xhorse never make read by k-line!
    some time you must use personal skil.
  6. The Following User Says Thank You to Brat For This Useful Post:
  7. #4115
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    in car or on bench, both work success... (of course key pass only when desolder HC05)
    on bench +12V, GND and K-line, not need more, for reading need only wakeup ezs
  8. The Following User Says Thank You to daxxer For This Useful Post:
  9. #4116
    Jan 2017
    In the "read eeprom" menu there is a window for keypass, this optipn will not work? And how can i wake the ezs up when its on bench?
  10. #4117
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    small window for keypass are prepared for insert key pass readed from big old key for example... and after save whole ezs dump+keypass together as HC05 dump
    wakeup ezs ??? :-) insert something inside, can it be anyone key or piece of wood
  11. The Following User Says Thank You to daxxer For This Useful Post:
  12. #4118
    Jan 2017
    Will try that thank you very much.. thought that it will be the end of resoldering hc05 but it was too good to be true
  13. #4119
    soxten's Avatar
    Mar 2013
    Need help.
    Have a W210 that have som problem to turn key around in keylock
    Program tell me to "Renew EIZ"
    I try but it dont work, see picture.
    I have read keypass from Eeprom on key and save file.
    I try to write but it dont work
    I did move 2pc mcu to a working used EIZ but same problem, and cant renew...
    So hardware is working but my be fault in software in 1 or 2 mcu...
    Any tips?
    Need help!
    Skickat från min iPhone med Tapatalk
  14. #4120
    soxten's Avatar
    Mar 2013
    Default VVDI MB BGA TOOL
    I did take a other used EIS and renew it.
    But still have same problem... when I try to write my EIS file back it hang up on 80%...
    I did try 20 times but always the same...
    Why?
  15. #4121
    Mar 2016
    you didnt renew eis
    look at status - activated
  16. The Following User Says Thank You to alexxxb0450 For This Useful Post:
    PierreTheron (26th May, 2018)
  17. #4122
    soxten's Avatar
    Mar 2013
    Sorry wrong photo, I have made renew.
    It write my file to 80% then it stop and say fail
  18. #4123
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by soxten View Post
    i not understand what you want to do ????
  19. #4124
    soxten's Avatar
    Mar 2013
    I need to write file from broken EIS to used EIS.
    I have renew used EIS, but then I cant write my file back to used renew EIS.
    It stop on 80% writing.
    You understand now?
  20. #4125
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    You understand now?
    yes...ok, now i then not understand, why you not rewrite mcu's content when you have it desoldered yet...
    you only waste time now...
    and in other case, when you want to use used EZS, then you can only make new key and renew ecu with esl and teach back and all finish....its more simply
  21. The Following User Says Thank You to daxxer For This Useful Post:
    rola1971 (18th December, 2017)
