>>This morning I tried another W212 Eis but renew failed again : specialkey 1D613C9C0E65CFC2 and erase FB1161124710F799
Erase pass match's special.
>>Is key password always needed to renewing EIS ?
Yes must have valid password unless nothing can be done.
>>Every attempts failed cost 1 token!
Such is life.
Hi guys. I am not seeing any C219/W219 on the drop down menu. I need to diagnose why the key is non responsive. How do I approach this job?
Sent from my SM-G930F using Tapatalk
trinicolin (30th July, 2018)
hi i have problem with read key with nec adaptor i use last 2 version 4.0.0 and 4.0.1 problem is some bug or adapter? with previous version i do not have problem to read and renew key v51
I did read a NEC with adapter two weeks a go with the latest software.There was no issue.
One recommendation for nec v57 and v51, it is much better to do them as a normal bga, making lists and uploading them to server (I am not an owner
of VVDI MB device, so I don't know exactly they do it...), if you have some problematic EZS then this should be a highly recommended way to do it.
Also if you have only one key and the chance of screwing up the nec is 50-50% then I would not play with the working key putting nec on board for password extraction.
regards ficho
jonny r (3rd August, 2018)
Yes. One I killed was an r230 so eeprom for the spare key anyways and just replaced the NEC chip
The second was a damaged key on a w211. When it didnt work I soldered to a spare board and did data acquisition.
Just annoying when it used to work perfectly
Sent from my SM-G960W using Tapatalk
Can anyone kindly help me calculating the password for a w221 that I need to add one key. I have the data aquisition done, but I am out of calculating tokens and if I purchase the tokens now it will pass 1-2 working days untill I'll be able to calculate passwords online. I'm uploading the data aquisition file. Maybe one kind friend that has the unlimited tokens can help me. Thank you verry much!
