rojhat (23rd August, 2018)
http://blog.xhorsevvdi.com/how...ool...-to-bga-token/Envoyé de mon MI PAD 3 en utilisant Tapatalk
I have problem renew gearbox 7g-tronic. Password get, but no renew. Log send here.
Each day you will be given a token if you own a CONDOR machine. In the event that you use it then it will be FREE. However at the end of the day (China 12AM) the token resets. So if you used you one FREE token then again you will have 1 token. If you didn't use it then that particular token for the day is expired and you have another 1 FREE token for the next day.
Depending where in the world you stay, you could manage to use 2 tokens if you plan the GMT+8 timing according to your time zone.
Example if 00:00 GMT 8+ is at 14:00 in your country, then you could use 1 token before 14:00 and another token after 14:00.
However because they don't accumulate then you would only have 1 free token and if you need to a process which require 2 tokens at one go (Eg W204 all keys lost) then you need to purchase additional tokens or the yearly unlimited option. If you have 1 FREE token and you do a W204 all keys lost then it will first take 1 token from your daily free and then it will take from you PAID tokens.....
nickolasd (31st August, 2018)
Hello. I have a problem and I do not know what is due!
I can not communicate with ELV w204 original and neither with emulator. I need to adapt an emulator w204 (in car and in work table, in both there is no communication)
or remove the FatalError,
with EZS w204 if I communicate and have no problems
my version is the last V4.1.
some help?
@araday ok, perfect, that's right, ELV with k-line + crocodile clip together OBD VVDIMB connector,
Thanks, I thought I could read by OBD alone
