Page 341 of 450 FirstFirst ... 241291331336337338339340341342343344345346351391441 ... LastLast
Results 5,101 to 5,115 of 6745
  1. #5101
    Need to connect to PIN 3
    No need for crocodile clip when connecting on table
  2. #5102
    khalilo_de's Avatar
    Hi dk's
    Today i managed to renew eis w204ء extract eraspass and password
    Then got renew failed
    Tested on 3 eis same issue
    Vvdi v 4.0.0 and v4.1.0
    Both same issue
    Ir read data okey what is the problem
    Regardd
    Envoyé de mon SM-G950F en utilisant Tapatalk
  3. #5103
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by khalilo_de View Post
    Hi dk's
    Both same issue
    Regardd
    mostly its operator fail....
    many thanks to friend kevfield
  4. #5104
    khalilo_de's Avatar
    Quote Originally Posted by daxxer View Post
    It is not my first time using vvdi mb
    I done a lot off w204 w212 eis renew
    This time i do not now what happned
  5. #5105
    paste here sonder hash and your erase pass, to check them
    regards ficho
  6. The Following User Says Thank You to ficho For This Useful Post:
    khalilo_de (3rd September, 2018)
  7. #5106
    khalilo_de's Avatar
    Quote Originally Posted by ficho View Post
    regards ficho
    Tomorrow i will do
  8. #5107
    asmn's Avatar
    Aug 2010
    Hi dk's
    Both same issue
    Regardd
    Recently had the same issue. Couldn't renew EIS W204, done a lot before but this time for some reason can't.
  9. #5108
    lpf01's Avatar
    Oct 2013
    Anybody have issues with data upload?
    I try to calc a w204 key pass, data collected ok, but when i try to upload always get Operation timed out error.
    Az én iPhone készülékemről küldve a Tapatalk segítségével
    Countless lockpicking stuff, AVDI Original, Tango, Orange 5, TMpro2, sooo mutch chinese stuffs from FVDI Full through VCDS to Benz key programmers, 3 cats and hopefully still 20 fingers......
  10. #5109
    khalilo_de's Avatar
    regards ficho
    Here is issue
  11. #5110
    Select box "allow user" in up right corner and erase
  12. #5111
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by Brat View Post
    this sure not help
  13. The Following 2 Users Say Thank You to daxxer For This Useful Post:
    AjDaBeast (28th September, 2018), khalilo_de (4th September, 2018)
  14. #5112
    khalilo_de's Avatar
    this sure not help
    So what is the problem ??
    Is the eis version not supported ??
    It is not fbs 4.
  15. #5113
    Apr 2015
    It is not fbs 4.
    From the screenshot the caused reason maybe on IR or EIS.
    please send me the proper log file or let me teamview check.
  16. The Following User Says Thank You to Samic For This Useful Post:
    daxxer (4th September, 2018)
  17. #5114
    @khalilo_de
    Since your erase pass matches your sonder hash, and your vvdi box hardware is working ok, then the only thing left could be the calculated password.
    Can you do a password check on your key or ezs ??? since I am not a vvdi owner, I do not know if it has such possibilities functionality implemented.
    regards ficho
  18. The Following User Says Thank You to ficho For This Useful Post:
  19. #5115
    Nov 2015
    @khalilo_de
    can you read eis data via IR ?
    sometimes problem for IR adapter because IR adapter not have good quality
