Of course. Some will not allow it, but most W203 will.
iozo, read carefully what I wrote for your case - in my previous post:
"...you need to program it(the original key) again for it to work again."
Meaning - you need to erase the original key and write the newly generated key file for the position it was programmed before.
You're welcome, BTW!
iozo (10th October, 2018)
Did you try with the dedicated "Renew" button in the VVDI software
Hint: your key shouldn't be a BGA. By how you describe it - it should be a BE key.
If it somehow really is BGA - then you better throw it in the bin
May we lose the keyless go function for the original key if we work on a car that is equipped with keyless go function? I'd like to add a BE as a spare key but somebody mentioned in this topic that the car lost the keyless go function.
Is it possible to do AKL W212 on the car without removing eis?
auto techniek (10th October, 2018), jonny r (10th October, 2018), rokibar (10th October, 2018)
Hi Samic , how are you !?
I have a vvdi bga always worked well but now i need to renew vgs fdct ( new generation but still fbs3 from w117 ) and i can t comunicate with it , even on bench ! is there a solution !?
regards
