Page 53 of 450 FirstFirst ... 343484950515253545556575863103153 ... LastLast
Results 781 to 795 of 6745
  1. #781
    habbyb's Avatar
    Romania
    Hello Daxxer,good question . I do not know exactly do you think it would work on table would replace the original elv ??? for test ezs with key.
  2. The Following User Says Thank You to habbyb For This Useful Post:
    daxxer (24th June, 2016)
  3. #782
    Feb 2014
    Just extracted pass by IR on a W203 for under 2 minutes. Wonderful!
    But the key I prepared(second hand) is only able to lock and unlock the doors and doesn't start the car. Tried inserting many times, also left it for a few minutes in the slot and still nothing but lock and unlock the doors(only shows that it is calculating on the dash screen). Could the problem be in the second hand key?
  4. The Following User Says Thank You to autoTkey For This Useful Post:
  5. #783
    kevfield's Avatar
    uk
    Try using a used key slot
    Thanks Kev
    Sent from my GT-I9192 using Tapatalk
  6. The Following 2 Users Say Thank You to kevfield For This Useful Post:
    autoTkey (24th June, 2016), gilahish (15th March, 2017)
  7. #784
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by autoTkey View Post
    when show in display ""calculating" then is need to wait !!! the process can begin from 1 sec to 2 hours !!!
    don't want to have keys functional in EZS/EIS everytime only in 1 second
    P.S. ...is important to know, when is your second hand key sure in 100% condition when is the key inserted in EZS/EIS, then is on dash "calculating" and the LED on the key is ON or flash...??? then wait...
  8. The Following User Says Thank You to daxxer For This Useful Post:
  9. #785
    Feb 2014
    Maybe but client didn't have 2 hours and had to go, so promised to return on monday. We'll see.
  10. #786
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    yes, but is described in WIS, when can so long time needed for this process....mostly when you use another key for used position...then the rewrite is longer then write to non-used place...
  11. The Following User Says Thank You to daxxer For This Useful Post:
    derdud (24th June, 2016)
  12. #787
    Feb 2014
    It was not a used position. I'll report on monday when I try on a used position as kevfield suggested.
  13. The Following User Says Thank You to autoTkey For This Useful Post:
    purdy (28th June, 2016)
  14. #788
    habbyb's Avatar
    Romania
    Mate...what do you want to do with this ELV simulator ?
    Hello Daxxer it is elv emulator see link http://www.vvdishop.com/wholesale/elv-simulator.html
  15. #789
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by habbyb View Post
    I see the link and content before...don't worry...but at the topic is writed "simulator" and bottom under photo is "for ESL W204 emulator"
    what is true of all that ?
  16. #790
    Feb 2014
    Quote Originally Posted by kevfield View Post
    Thanks Kev
    It helped, thanks. Had to reinsert it 3-4 times but didn't have to wait for 2 hours.
  17. The Following User Says Thank You to autoTkey For This Useful Post:
    kevfield (27th June, 2016)
  18. #791
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    yes, sometime helped insert...wait 2-5 sec or till the LED of key light...take out...insert again....wait (.........).....take out.....insert again.... and for example this steps repeat 5x
  19. #792
    CaioW's Avatar
    Oct 2015
    Everywhere
    Guys, im trying to generate a key from one W209 and cannot.. when try calculate the key, the software crash..
    can someone try to do the keys? please? Version 51.
    Thanks for your help!!
  20. #793
    rola1971's Avatar
    Jun 2014
    Dublin
    209_key.rar
    it is you key
    good luck
  21. The Following User Says Thank You to rola1971 For This Useful Post:
    CaioW (27th June, 2016)
  22. #794
    CaioW's Avatar
    Oct 2015
    Everywhere
    Quote Originally Posted by rola1971 View Post
    209_key.rar
    it is you key
    good luck
    How do you do?
    HEre just with that bin, the software CRASH..
    Thanks alot
    edit: I found the problem, if you unmark V41 and 11 to do just the V51 the software crash, now ive tried marking all, and the software calculate the keys.
  23. The Following User Says Thank You to CaioW For This Useful Post:
    daxxer (27th June, 2016)
  24. #795
    kevfield's Avatar
    uk
    Quote Originally Posted by CaioW View Post
    How do you do?
    Thanks alot
    Same happen to me today leave all ticks and all keys made
    Thanks Kev
  25. The Following 2 Users Say Thank You to kevfield For This Useful Post:
    CaioW (27th June, 2016), daxxer (27th June, 2016)
