Page 189 of 450 FirstFirst ... 89139179184185186187188189190191192193194199239289 ... LastLast
Results 2,821 to 2,835 of 6745
  1. #2821
    May 2010
    Quote Originally Posted by obeids View Post
    So I tried the following.
    I connected up the set and READ EIS. Then presses the PERSONALIZE W204 ESL. It said succeeded. However when I take out key and reinsert then the ESL went to lock position. When insert key then no response. So I go to read ESL Data and it shows now TP CLEARED. However the Personalised and ACTIVATED are still showing unticked in the boxes.
    I tried more than 10 times to personalise and same thing. Should I just read EIS data without password and write it to ESL and select AUTO CLEAR TP and PERSONALISE?
    Really appeciate help.
    you have to load the ezs dump into the esl and write it.
  2. #2822
    Aug 2009
    Paraguay
    Quote Originally Posted by jonny r View Post
    Hello
    Special Key: E4156DC1BC6D4137
    Erase Pass: DFBBE1A767940B62
    Regards
    Jonny
    Many Thanks Mate!!!
  3. #2823
    May 2013
    Quote Originally Posted by vageric View Post
    Hi.
    So the EZS dump without key password and Erase password will still work?
  4. #2824
    May 2010
    no the ezs dump with key password and without Erase password shout work.
  5. #2825
    Sep 2010
    Hi all
    Plwase i have pribwith renew tcm
    Whan i have w164 and renew and then need prigram uts on w212 isnt accpt that
    Is there sulation to do that
    Regards
  6. #2826
    Apr 2010
    Hi.
    CAR W204
    ERASE PASS:???
    SPECIAL KEY: 7CF455C24D66776F
    Please,
    Thank you in advance.
  7. #2827
    dd1's Avatar
    Aug 2014
    Hi everyone. So I have successfully repair ESL, W204. Now, what's my next step? I'm using vvdi2 2.1.7 version. What are the steps. Thnx in advance
  8. #2828
    Apr 2010
    W211 with ST-12 - client washed their keys and would no longer work. v40 so I wouldn't be able to extract password from the key NEC (and couldn't read password via IR)
    I WAS however able to read the key via IR with VVDI. After i put the EIS back in (made key on the bench) I was wondering if I could do password acquisition using that key even though the EIS wouldn't recognize it?
    For myself or anybody else in the future, is this possible to do? I have a free token so I wouldn't mind using it instead of removing the kick panel in the dark.
  9. #2829
    Nov 2009
    workshop
    swap nec from old key to donor
  10. The Following User Says Thank You to mercis For This Useful Post:
    dmp (26th April, 2017)
  11. #2830
    Apr 2010
    Quote Originally Posted by mercis View Post
    Yepp that would have been far less work. Much better idea, knew there was a simpler solution vs what I went through!
    Cheers
    Sent from my SM-G930W8 using Tapatalk
  12. #2831
    Nov 2009
    workshop
    read eis,generate and make new key
  13. #2832
    CaioW's Avatar
    Oct 2015
    Everywhere
    If you need to use password calculation online the car must have CAN comunicaton, if KLine, the opcion will not work.
  14. The Following 2 Users Say Thank You to CaioW For This Useful Post:
    labusas (26th April, 2017), rola1971 (26th April, 2017)
  15. #2833
    Aug 2009
    Paraguay
    HI mate, I use this erase pass Special Key: E4156DC1BC6D4137 Erase Pass: DFBBE1A767940B62
    to renew my EIS W204 and when device erasing say erase failed in 95 % and now I cant do anything!. Please need help!
    now say no personalized and no Active, and can reprogram again
  16. #2834
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by ant21000 View Post
    this is bad, you are not so much lucky man now...
    i maybe have some solution, but need to try it
    many thanks to friend kevfield
  17. The Following User Says Thank You to daxxer For This Useful Post:
    rokibar (26th April, 2017)
  18. #2835
    Aug 2009
    Paraguay
