Page 296 of 450 FirstFirst ... 196246286291292293294295296297298299300301306346396 ... LastLast
Results 4,426 to 4,440 of 6745
  1. #4426
    Nov 2009
    workshop
    check microswitch on eis,
  2. The Following User Says Thank You to mercis For This Useful Post:
    wissamshaat (15th February, 2018)
  3. #4427
    Jan 2011
    anyone have problems with sync i cant connect to server keeps failing stupid problem cant use the tool because of this
  4. #4428
    Maartinj's Avatar
    Nov 2010
    Poland
    Quote Originally Posted by insomnia2009 View Post
    some temporarly server issue,
    make sure you have latest SW and try use 3G connection
  5. #4429
    Nov 2009
    Minsk, Belarus
    Hi friends! Pls calculate Sonder Hash of BE 4A 2E 6B EA 95 CE C3 for renew ISM.
  6. #4430
    Aug 2010
    Quote Originally Posted by adikk View Post
    Hello,
    Regards
  7. The Following 5 Users Say Thank You to jonny r For This Useful Post:
    adikk (16th February, 2018), CarCity (17th February, 2018), ficho (17th February, 2018), habbyb (20th February, 2018), tferenc (18th February, 2018)
  8. #4431
    Jul 2015
    I tried to use VVDI MB 3.7.0 for W204 data acquisition via OBD. I get error message about no connection to OBD or power loss (it wasn't the exact fault message). I didn't know why I got this fault because I could read the EIS data using VVDI MB EIS tools whenever I wanted on this car.
    Finally, I performed the data acquisition via IR but I'm curious about this fault.
  9. #4432
    dd1's Avatar
    Aug 2014
    Hi everyone. 2003 mbz e class w211, I want to swap the Eis, with a key, from another car since my eis has some issue. Will the vvdi2 bga tool do this job without opening the eis and reading eep???? Maybe like obd2 or IR reading would be enough for this job? Thnx in advance
  10. #4433
    Jan 2017
    Hello.
    I tryed to make a key with lost keys in Mercedes W203. I tryed to get password for IR and give me an error about Current EIS don't support read password via IR.
    Can anyone help to get password for this car???
    Thanks in advance
  11. #4434
    Nov 2009
    workshop
    VVDI CANT FIND(MOTOROLÍ)READ EIS WITH ROSFAR XPROG R270... UPLOAD DUMP TO SKC AND SEE PW
  12. The Following User Says Thank You to mercis For This Useful Post:
    doctore (6th March, 2018)
  13. #4435
    dd1's Avatar
    Aug 2014
    Quote Originally Posted by mercis View Post
    My eis is with a key.
  14. #4436
    drugowaz's Avatar
    Mar 2015
    Lithuania
    If you read pass by IR you can do it. If not you need read bdm. Doest matter you got key or no.
    Ive never managed to read it by IR. Always bdm
    Renault ECU tool / IO terminal / A.S.W
  15. The Following 2 Users Say Thank You to drugowaz For This Useful Post:
    dd1 (21st February, 2018), Faraday (21st February, 2018)
  16. #4437
    dd1's Avatar
    Aug 2014
    So I can read the eep in order to swap used eis? Will the start with the original key or I have to use the donor key also? Thnx
  17. #4438
    Moderator
    PremierD's Avatar
    Jun 2009
    Think about it mate .. the eep you read will have the original key data in it ... so which key should you use ?
  18. #4439
    habbyb's Avatar
    Jun 2010
    Romania
    Hello , zed full comes strongly from behind with mercedes 204/207 212 all key lost ,we are waiting for new news from VVDI MB BGA . SUCCES
  19. #4440
    Apr 2010
    Quote Originally Posted by habbyb View Post
    Are they coming with 164 545 13 08, 164 545 09 08, ... All Keys lots ???
