Hi everyone. I have done a Mbz w204 ELV repair and no it shows notPersonalized or TP unticked. What's my other option? I'm using vvdi2 mb. I have not done a EIS renew because the version 2.1.7 should do it without that. Before had "fatal error" in ELV. Help plzzzzzzzzzz. Thnx in advance
In this thread is all described, don't be lazy and read it, you sure there find answers for your questions![]()
many thanks to friend kevfield
Updates are overdue, otherwise it's a great piece of machine
Sent from my A718 Xplora Plus using Tapatalk
Yes mate, I only have the VVDI
I'm still stuck with this els issue. Anyone else can help me? Can't personalize and activate.......
dd1 (29th April, 2017)
daxxer (29th April, 2017)
Sprinter eis
Erase pass please.
special key: 5E20428793505045
Many thanks in advance.
Hello, Please help calculate Erase password for EGS Renew W219
special key: 72C2176B386389F5
Thanks!
VAG BCM2 clone, Repair errors, ELV sync, EDC17/ MED17 Clone, CVN fix.
habbyb (30th April, 2017), jonny r (2nd May, 2017), SergeyGrodnoBY (29th April, 2017)
VVDI MB BGA Tool Power Connect Adapter Function:
1. Mercedes-Benz power adapter can be used in the FB3 system all lost and gateway simulation, support:class C, E, CL, CLK, MK, GL, GLK and other models.
2. Use the Mercedes-Benz power adapter to collect W204, W207 all lost, only need 18 minutes.If not use the Mercedes-Benz power adapter will take about 150 minutes.VVDI MB power connector will help you save lot of time for nearly 2 hours.
3. Use VVDI MB Tool power adapter to collect W216, W164, 2009 + all lost, do not need to plug the infrared adapter (item NO.SF210). If without the Mercedes-Benz power adapter needs to plug 500 times, this adapter help you operate easily.
4. Support gateway simulator function, without the gateway,you can get access to W164, W164 2009 +, W209, W211 (need to use a dedicated linear beam cable) directly by OBD way.
5. Mercedes-Benz power adapter works with VVDI MB Tool will release more functions in future
habbyb (1st May, 2017)
