Results 1 to 5 of 5
    rob h's Avatar
    May 2011
    Default Aston Martin DB9 2010 spare key
    Hello guys,
    This car, is from the US, 315mhz key.
    This type off key, need to be inserted in dash slot, to start the car.
    I have found some used keys, on ebay.
    Can i reuse these?
    Is the transponder locked? My guess, it is a 4D.
    Is there match, between the transponder data, and remote data.
    I will read out the key, to check exact what transpnder is inside.
    i found a picture, showing what is inside.
    202 YW 07247853
    IC: 5461A-7003186 STRATTEC
    P/N: 7003186
    FCC ID: OHT7003186
    8D33-19G220-A 315 MHz
    2005 - 2016 ASTON MARTIN DB9
    Apr 2010
    Transponder reusable. Remote is a volvo remote and not reusable.
    Can clone working key
    Sent from my SM-G960W using Tapatalk
  3. The Following User Says Thank You to dmp For This Useful Post:
    rob h (12th April, 2022)
    rob h's Avatar
    May 2011
    Thank you,
    i have seen some Volvo keys used, on some types.
    This key, looks lke a cheap version off the crystal key.
    I have seen some, with the barcode.
    Yes that looks like Volvo systems.
    So we can not program any off these.?
    This one, with 4d transponder, i could clone.
    So i will look for a spare casing, to place the transponder in.
    The owner should contact the dealer, to ask about a new key.
    There is no keyblade, inserted in the keyfob.
    Doorlock is a tibbe, i will make a keyblade.
    Anyway, thank you,
    Greetings Rob
  5. The Following User Says Thank You to rob h For This Useful Post:
    sogaro (25th August, 2022)
  6. #4
    Dec 2022
    Did you read out the transponder? Does anybody knows wich transponder this key has? 4d60 maybe?
  7. #5
    rob h's Avatar
    May 2011
    Dont remember exact. only what i wrote, 4d. . They did not want a spare key.
    So i did not bother to cut a simple doorkey, and and copy the transponder. Just in case he lost his key.
    Waisted to much time, on that guy.
    Tango, add 4d direct to the ecu.
    Aston Martin DB9 2004
    Original transponder
    TIRIS DST 4D
    Allowed transponder
    TIRIS DST 4D
    Data location ST77014 (read as 25040 / 95040)
    No. of keys 8
