Page 1 of 3 123 LastLast
Results 1 to 15 of 35
    Nov 2010
    Kiev Ukraine
    Post 2014 Audi Q5 Steering Assist 8R0909144 Check Sum Error
    Hello, 2014 Audi Q5 Steering Assist 8R0909144B SPI-25320 CheckSumError
    Problem after crash:
    Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
    Part No SW: 8R0 909 144 G HW: 8R0 909 144 B
    Component: RCEPS H40 0508
    Revision: 00001000 Serial number: 0024245805
    Coding: 100000000000
    Shop #: WSC 06334 000 00000
    ASAM Dataset: EV_RCEPSAU48X 008015
    ROD: EV_RCEPSAU48X.rod
    VCID: 3C7C20D8B706C8DE41-8068
    1052432 - Internal Control Module Memory Check Sum Error
    B2000 49 [137] - Internal electronic failure
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 1
    Fault Frequency: 1
    Mileage: 47914 km
    Date: 2015.09.08
    Time: 15:17:18
    0770 - Internal Control Module Memory Check Sum Error
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Mileage: 47733 km
    Date: 2015.06.30
    Time: 17:28:47
    I need similar dump for finding CRC or original dump with correct CRC.
    Thanks in advance.
  2. The Following 3 Users Say Thank You to s-sanya For This Useful Post:
    br.balazs (14th February, 2017), mcday (24th December, 2018), ra4yel (30th March, 2017)
  3. #2
    Nov 2015
    I have but I Do not Know How to add AUDI A5 cupe 2014
    You find the solution to this problem?
    One error you eliminate the upload flash. You can use the VCP.
    This is a CRC error but it does not have to be.
    look:
    I had two Audi A5 approximately one without error
    the second after crash
    Audi A5 no crash good Steering assist 95320 free errors , I've done backup .
    Change module steering assist from good audi to audi after crash .
    Chceck errors and read this some errors cheksum error .
    disassembly stering assist from crash audi and i done restore eeprom 95320 and back module to good audi and something strange happened in this car also enrolled in this error cheksum error .
    I started concluded that something is happening in the Flash D70F3483F but no programmer that support this processor.
    I'm looking all the time to solve this problem.
    Link which I found, try to ask this person, says he did.
    http://www.carhelp.info/forums/showthread.php?t=127141
    Please give information on how to deal with this.
    Best Regards
    MArio
  5. The Following User Says Thank You to mariopl For This Useful Post:
  6. #4
    Nov 2015
    solution to clean crash
    BestElectrical's Avatar
    San Diego, CA, USA
    Default solution
    Quote Originally Posted by mariopl View Post
    look:
    Best Regards
    MArio
    Solution that usually works is reflash. I usually reflash using AVDI and Audi data files.
  8. #6
    Dec 2015
    Same problem. B200049 after crash. Used odis to reflash, now b200000 error)
  9. #7
    Mar 2014
    Hello
    I have a problem with q5. Car had a little accident on the right side, exploded airbags. Airbags repaired and error cleared, but the power steering still does not work and it is a problem with the check sum error. I not cleaned crasch date because it was not stored in the airbag sensor. The driver steering assistance was updating file FRF audi the help of VCP.
    Can you advise me what to do with this problem ?? I will be grateful.
    Matthew
  10. #8
    Aug 2012
    BALTIC
  11. The Following 2 Users Say Thank You to seattm2012 For This Useful Post:
    br.balazs (14th February, 2017), mcday (27th December, 2018)
  12. #9
    Aug 2012
    BALTIC
    anybody help me
  13. #10
    Jun 2012
    I have same issue and looking for solution, any ideas which tool to used? I heard that VAG COM PRO may work, but which file to updated? Any solution for FLASH reading/writing?
  14. #11
    Dec 2015
    Try to reflash with odis or vcp.
  15. #12
    Jun 2012
    To re-flash it with ODIS, it's asking for SVC code input, do have it?
  16. #13
    Try to use Odis-E, usally doesn't ask any codes, only confirmation yo know what you're doing.
  17. #14
    Jun 2012
    Update, friend of mine found FL_8K0909144F_0507_BP.frf file, which then we force upgrade via ODIS E to the module, now I have one extra error. I am thinking, is this really hardware issue like on Mazda's module? Or it's still a software issue.
    6291727 - Internal Control Module Memory Check Sum Error (B2000 00 [137] )
    7341570 - Position Sensor for Motor (C10AD 29 [137] - Signal Implausible)
  18. #15
    Mar 2014
    Hello
    I solved the problem of replacing the power steering driver. I looked into the old controller and found burned coils and other items. It is very strange that the driver is damaged during an accident. I tried updating the VCP and Odis-E power steering driver but it did not help.
    I replaced the driver itself and power steering returned.
  19. The Following User Says Thank You to xxmatixx For This Useful Post:
    DreamDancer (25th December, 2017)
