Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
  1. #16
    Sep 2015
    Washington, DC
    Quote Originally Posted by ray-ray View Post
    What the trick? Can it be done with the "Pro" ? These will help all USA member save time. Are you willing to share your info.
    will ilco/AD be adding these to there tool?
    Ray I can't say what it is because I'm working with AD to get it onto a MVP @ the moment
  2. The Following 2 Users Say Thank You to Kinskeys For This Useful Post:
    Automat (3rd November, 2015), ray-ray (3rd November, 2015)
  3. #17
    In a van down by the river
    Borrowing technology from Tango and feeding to AD?
  4. The Following User Says Thank You to indienick For This Useful Post:
    Automat (5th November, 2015)
  5. #18
    I like how the video shows how fast the service is, but you had already taken time to arrange your laptop, load your software, cut your key, program your remote (I know the remote + transponder is two separate procedures for this car, but your video makes it seem as if they are programmed together), determine the car takes G chip.
    "done in 5 minutes".
    oooookkkkkkk
    do not get me wrong, the immo quick reset is cool but let's keep it real here my friend.
  6. The Following 2 Users Say Thank You to indienick For This Useful Post:
    Automat (5th November, 2015), paul_12345 (4th November, 2015)
  7. #19
    ray-ray's Avatar
    Only a Rookie would have not notice the remote section. AD need to keep the "PRO" held of the "MVP" (Pro was the foundation to the Company) (MVP are just leasing space on are foundation).
    so soon qwick reset for "G" and "H" so how about bypass Nissan 20 digit (taken from zed full)?
  8. The Following User Says Thank You to ray-ray For This Useful Post:
  9. #20
    Ordered a remote dongle. Will post results soon as I have them. Interesting item....
  10. The Following User Says Thank You to indienick For This Useful Post:
  11. #21
    Aug 2014
    Quote Originally Posted by indienick View Post
    Hi, indienick, I guess you received your remote dongle, right? how about it? would you please post here the results?
  12. #22
    ray-ray's Avatar
    I order 2 myself will post USA market cars on Tuesday.
  13. The Following User Says Thank You to ray-ray For This Useful Post:
    Automat (2nd December, 2015)
  14. #23
    May 2015
    Have you figured it out ? It would be interesting to test it out with the H key as well.
  15. #24
    Quote Originally Posted by austingreen View Post
    Thanks, sorry I did not reply back until now. I had not been on DK in a while.
    It works perfectly fine. I had not used it until now to do immo but remote programming works as advertised. Very simple. Tested on Toyota Highlander and Toyota Rav4 until now.
    Separate key and remote on these cars that I tested.
  16. The Following User Says Thank You to indienick For This Useful Post:
    Automat (11th December, 2015)
  17. #25
    DK Veteran Automat's Avatar
    Chuichu village, AZ
    What years did you test Indie?
  18. #26
    Aug 2014
    That's fine. Wait for your more tested result.
  19. #27
    ray-ray's Avatar
    Remote section works perfect no problem tested on a 2009, 11, 15 Camry , RAV4 , Prius C
    tryied to add the G but did not work. ( the tool did go through it cycle and the immo light did go solid )
    i think I was missing a step. It ask you close the door and turn key then connect to the obd2. A couple of beeps
    Later the next thing the immo. Light goes solid , you remove the master and insert the add key to the ignition. Light goes back to blinking. Next time I will try it with the door open.
  20. The Following 3 Users Say Thank You to ray-ray For This Useful Post:
    Automat (16th December, 2015), lion0304 (16th December, 2015), totalkey (16th December, 2015)
  21. #28
    Aug 2014
    So problem solved now?
  22. #29
    Apr 2017
    i picked up one of the green OBDII dongles and tried it today on an '09 yaris made in japan for north america.
    works perfect.i programmed the transponder chip (dot 4d67) and tried to reprogram the original key fob and it worked fine.
    the new key had no fob on it.i had another fob remote but it would not program--i'm sure the key is bad (jobber).
