It's an old thread but i am also lookng for the same eeprom dump, can anyone help ?
TIA
Nogger1
TIA
Nogger1
Before 1 months i have problem x1 2010 or 2011...my board burned...i change genuine processor to second hand board and job done ... This is genuine box
Now this processor on picture from second hand board...i sure second board other numbers but not remember...
Numbers of second hand it was different
If need to try i will read this and post
Excellent, a dump would be appreciated
Nogger1
can you tell me how to read this processor....
I have etl but not support this mask
upa read this...?
i used XProg v5.55 , only 4 wires. I think UPA can read but i dont have connections,
Can you send me photo
You can use any eeprom from good FRM3..
After you have to Write VIN and flash by WINkfp. Read VO from Cas the write it to FRM.
It work 100%
this is all from processor ...eeprom p-flash d-flash ...
armpower (9th May, 2017), DOUGLASDL (19th May, 2017), dritan (11th February, 2017), juanes 3 (13th November, 2016), luthor (10th November, 2016), mastaflex (16th June, 2021), mossa19 (10th February, 2017), MV auto (22nd May, 2016), n599fbm (14th November, 2016), Noel73 (22nd February, 2018), nogger1 (4th May, 2016), pataroucci (9th June, 2017), reginaldo (12th January, 2017)
Sent from my E7 using Tapatalk
Thanks Vasko , i will give it a try
Nogger1
I got the same module for an E87 problem is i am getting all 00 when i reed the EEPROM section anyone has an idea why?
I know its an old post bot hoping someone knows why.
Edit: I am using UPA to read it and i can read p-flash but i cannot read EEPROM
6135-9224592 with 9S12XEQ384 - 3M25J Mask
