Page 2 of 144 FirstFirst 12345671252102 ... LastLast
Results 16 to 30 of 2152
  1. #16
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    Here you go. Signal for that error switched OFF
    All brand FileService - Custom - remapping company
    POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
    | Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
  2. The Following 2 Users Say Thank You to CustomCars For This Useful Post:
    dominatori (23rd November, 2015), pike (23rd November, 2015)
  3. #17
    pike's Avatar
    Sep 2013
    Hi CustomCars.
    Bosch EDC16C34 0281012982
    I need DTC remove P0409 P0490 P1162, please.
  4. #18
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    here you go mate.
  5. The Following User Says Thank You to CustomCars For This Useful Post:
  6. #19
    Top Poster + denis1hr's Avatar
    Jun 2009
    near you....
    Here is the file.
    03G906018EM.ori.rar
    Car is Passat 2.0 TDI PPD1.2
    The fault on VDCS is: 008194 _ Particulate Trap Bank 1
    P2002 - 006 Efficency Below Threshold
    Thanks in advance.
  7. #20
    Hi CC, can you remove DTC P0400 in file attached.
  8. #21
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    Quote Originally Posted by Theoros View Post
    here you go, attached to files with different method for remove your problem :-)
  9. The Following User Says Thank You to CustomCars For This Useful Post:
    pike (24th November, 2015)
  10. #22
    thanks friend.It works perfect
    Quote Originally Posted by dominatori View Post
    Hello.
    Please let do dtc off to this file.
    Ford Focus 1.8 85kw ECU sid202
    dTC p0489
    Thanks you very much
  11. #23
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    Good to hear mate.
  12. #24
    Sep 2015
    sid201 land rover sport. DTC p213b , need turn off that dtc
  13. #25
    Babos's Avatar
    Mar 2012
    for best way for this ecus is full read via BDM!
  14. #26
    Sep 2015
    full bdm read, that you mean I need take out ecu and connect on table ?
  15. #27
    Babos's Avatar
    Mar 2012
    yes.
    This dtc can delete now in flash but can be limp mode active but in diagnostic you not see any dtc.
  16. #28
    Sep 2015
    ok, if can turn off that dtc
  17. #29
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    Quote Originally Posted by DendeLT View Post
    That's right for Siemens must have full BDM to make DTC correctly otherwise any off will be not work.
  18. The Following User Says Thank You to CustomCars For This Useful Post:
    PierreTheron (15th December, 2015)
  19. #30
    Sep 2015
    i dont have table, maybe someone have full bdm for that ecu ? lande rover 368dt 3.6. Or if can turn off dtc how you can, becouse other solution I dont have how read full bdm
