Yako1984 (13th November, 2020)
Please, turn off the DTC-P0420. ECU SIM210 Ford Fusion 1.4. Thank you!
krokodyl30 (29th January, 2018), Yako1984 (13th November, 2020)
Hello, i have a fiat bravo me7.9.10 16 valve aspirate no turbo.
i would like to remove lambda and p1171 and p1172 code someone can help?
please disable dtc P055F P0488 P0409 P0490
iveco daily edc17cp52
i have this dtc after diconnect egr valve
I need EGR OFF for 2007 Transit Connect 1.8 TDCI 90ps.
I believe its just a DTC removal but unsure if map has to be altered.
I have been told the DTC's are 0401,0402 and 0409 however there are more EGR related codes but unsure if they have to be deleted.
I am very eager to learn all of this
can anyone help? File is attached.
Thanks in advance.
brashy (24th January, 2018)
hello, did you do the file whit dtc removero or whit winols?
Hello Could you remove those dtc, in my edc15c2 flash ? Thanks thanks a lot
P1517, P1421, P1351, P1352
hi can some one delete DTC as below from my DDE
00483C boost pressure actuator
Hello, i have a trouble with a ford focus what has mass air flow sensor and intake air temperature dtc, I foun ecu was damaged and I change it by one used, but still dtc, I changed mass air flow but dtc still on, so, can you dtc off it for me ? I dont know what more can I do.
The dtc codes are:
P0100 mass air flow malfunction
P0102 mass air flow low input
P0113 intake air temperature high input
The ecu is bosch edc16c34 -2.30 0281011701 6M51-12A650-NC and engine is 1.6tdci HHDA
0281011701 focus desguace.rar
Please remove P0544
