Results 1 to 4 of 4
    Nov 2015
    Germany
    Question A4 B5 M73 Login Magneti Marelli
    Hi there,
    I am new to the matter of vehicle software. Not unexperienced in terms of electronics and
    programming in general though.
    I got a Audi A4 B5 in really good shape and would like to learn it a vew new tricks.
    Like putting in a remote control for the central locking i. e. (exchange original pump).
    But in order to get this to work, I need to teach the new keys into the immobilizer. And
    that requires me to know the Login code.
    Infos about the car:
    VAG#: 8D0 920 900 P
    Extra: WAUZZZ8DZ1Axxxxxx AUZ5Z0Y6124300
    I read many old therads in german forums but only got more confused as to how to do this.
    Having only an KKL - Interface here from eGay, I wonder if there is any software which could dump
    the eeprom? And how to extract the Login from such a dump? I am unsure because in a lot of
    old post I read that clone solutions messed up the clusters firmware. How likely is that?
    Which options do I have? What software, which interfce? I found a thread about CarProg.
    Would that be an option? And if so, which (clone) hardware does it require?
    Questions over questions,
    I hope someone can show me the right road to go, thanx a bunch!
    Apr 2011
    in lebanon
    Hello.
    you are well come to this forum = Dk
    1) Dear,i can give to you little websites which those trusted tool + good support. (1) http://www.smok.com.pl/index.php?lan...a=1&produkt=55 : (2) http://www.opelinfo.com
    2) and if you want work on more cars for vag you have vvdi1 + vvdi2 so this you can search on the web, carprog is good but for another thinks for your order not trusted tool.
    3) and good to have VCDS to adapt remotes or transponder keys,this is the best tool in the world + diagnostic.http://www.ross-tech.com/
    Nov 2015
    Germany
    Ok, thanks fo the hardware tips. I'll consider them and buy something later.
    For my actual problem with the immmobilizer and key lteaching:
    how can I read a dump from my old car, in order to find the login?
    Is there any cheap tool to that without messing up my firmware?
    I will dig into car electronics, but my problem at hand is to add the remote control.
    Thanx for help, all appreciated!
    Hi Urmel aus dem,
    I think this may be usefull for you.
    http://www.codecard.lt/immo/audi-vw/...c/prod_20.html
