etl hc908 problem
Results 1 to 8 of 8
    Oct 2015
    Default etl hc908 problem
    hi
    got clone etl hc908 programmer v2.7 but can't read anything. tried with mcu 2j74y and 1j35d but have messagess: reset line must be in high state. tried read in qfp64 adaptor and soldered at board. it is same. i was resolder all programmer but nothing news. any sugestion?
    roki
    Oct 2015
    nobady have not solution?
    Mario3's Avatar
    Dec 2014
    Had the same problem. After buying qfp64 adapter 90% of the problems where gone. For the rest i had mcus that are damaged and could not be read.. So are you sure that your mcu is not bad ? Try to read it in circuit with carprog it can also read flash..
  4. The Following User Says Thank You to Mario3 For This Useful Post:
    rokibar (11th November, 2015)
    Oct 2015
    mcus 100% ok. i read eeprom and flash with omega without any problems. 1j35d was read success as 4j74y and when put quartz 12mhz at pin 58 and 59 so i think something not ok with my programmer.
    best regards
    Dec 2017
    Series clone can not read as 4j74y all time.
    but it can be read as 2j47y and 3k85k at beginning with 8 "00" as ss but failed verification.
    then trying to upgrade from 2.5 firmware to 2.7 but can not pass check sum.
    then not long link as 2j74y, noe 3k85k anymore with same reset
    one need to be high issue.
    however, still can read ess mode by entering 8 "00""
    try to heat the mcu and read
  8. The Following User Says Thank You to lirinikut For This Useful Post:
    Dalplex (11th February, 2018)
  9. #7
    Dec 2017
    No. Heating does not help.
  10. #8
    I had the same problem.
    try to cool procesor before read
