Range Rover DIscovery 3 Immo Unit location
Results 1 to 2 of 2
    May 2013
    Default Range Rover DIscovery 3 Immo Unit location
    Hi there Guys
    I have a client that has A Landrover Discovery 3. Year model between 2006 to 2008.
    PROBLEM: No Keys - All keys lost.
    Type of Key and ignition Place: Ford HU101 Key Blade - Ignition on Steering column.
    Does this use the BMW EWS System or is it the New Ford system or is it something unique to these vehicles?
    Can I get it started by using a normal transponder chip readily available such as TPX1, TPX2, CN1, CN2,CN3, 7936, 7935 or something else? What equipment is needed to code a key? I have TM100, VVDI, Zedbull and X100 Pro.
    Also can somebody please give me guidance as to where is the IMMO unit located on this vehicle as I cannot find anything by the Gear Lever.
    Thanks alot guys
    Mar 2014
    West Sussex UK
    Immo is in BCM. If all keys lost then you need either a dealer supplied key or you can make a transponder using tmpro.
