need help asap please
Results 1 to 11 of 11
    Nov 2015
    Default need help asap please
    got here 2004 isuzu rodeo and I'm try to program the key for the guy here! i can't find any other way to find the pinched to program that key please if someone can help and give me the pin code
    https://plus.google.com/u/0/10809262...29911620002405
    picture of the box
    please help
    hi
    93c46, 8pin, 128 Bytes
    Opel: Frontera(1998-)
    read the chip and someone here will help you with the code
    Nov 2015
    hello and thanks for your msg ! what i need to read and how to do ? please help
    Apr 2012
    London
    hey
    key4man said for You already
    if You didn't decrypted basics of the basics from what was written onepost before - probably You are not ready do finish thistask, but anyway
    key 4man said that You have to find on You immobox's PCB small eeprom - 8 legs family is 93c46
    Use for read - programmer like upa, xprogm, vellon, orange, omega, iprog or any available - You should get file with 128bytes ...... then use proper transponder and software (or brain.exe) and transponder programer - and that's all
    if it is to much at the moment - just give a try for somebody with equipment and knowledge to do it in a feew minutes, trust me that even solderig can be taken as butcher job so dont kill somebodys car if You don't know howto do it.
    better go on scrab yard buy a few dashes and immoboxes/ecus and kill them on table - milion bucks experience!!!!!!
  5. The Following User Says Thank You to zyjekrc51 For This Useful Post:
    key4man (24th November, 2015)
    Nov 2015
    i got all equipment I'm used for program https://www.advanced-diagnostics.com...u-Go-ALL-MAKES
    and i used this to read date http://www.mytoolsforyou.com/automot...xtMaAqKE8P8HAQ
    i do locksmith for 10 years and I'm really pro and know what I'm doing ! but thats the first time we got some problem with 2004 isuzu rodeo and all isuzu service in USA shutdown and we can't get the pin code i really need and want you guys to help !
    and don't worry I'm not going to mess up the car ! just need to know how to do all key4man say but thats my first time handle with that kind of issue !! please try to help me step by step !
    Apr 2012
    London
    ok I see - the problem is that when I've started my carieer with pins/keys and files - I was to poor to buy plug and play devices as You linked in post above - so my first tool was china xprogm - and used dash from honda scooter - first desoldering and soldering again and traces on PCB damaged- but hey - my fu...up was only 10USD - then I bought another dash and another dash and boght new eeproms for buckup if something go wrong.
    Tools You listed probably can't read eeproms direclty - just by OBD socket- I'm not 100% surre because tese tools are still to expensive for me.
    I already gave You solution - buy eeprom programmer (list of programers - check post above) - desolder 93c46 fromPCB read it - attach file here and somebody will help You with preparing transponder for You or will extract PIN code from 93c46 memory content and then You are free to go with Your MVP PRO.
    Nov 2015
    what you recommend to buy ? i know u got for me big list but what u think the best and with no to much knowledge ( its not because I'm stupid or some i just got no 2 much time to play around ) i need some machine can read that think with OBD ! what u think the best for me ?
    Apr 2012
    London
    all from programmers listed above are good for simple tasks - orange5 can do some secured motorola's MCUS but it is up to You what You need, like I said before - I started with china clone xProgM version 5.0 now You can find higher version with better coverage of eeproms,i2c or mcus, flashes etc. but very good and easy to work is orginal UPA programmer - it is cheap, and has big list of supported ic's - You should find supplier on Your market - UPA has also a tool for developing scripts - and many users are preparing they own scripts as solution for not supported or tricky to read electronic components - so my advice find UPA programmer dealer in Your country
    here You have got link to UPA developer - programmer You are loking for is: UUSP-S
    http://www.elrasoft.com/
  10. #9
    Oct 2015
    gaborone botswana
    i think tech 2 can do the job if u cnt buy one then better attach dump like has been suggested before
  11. #10
    Nov 2015
    Apr 2012
    London
    as Ican see You are still looking for machines with one button solution - I know it is convenient but no progress in Your knowledge area accures - I haven't got idea if it will work for You but autel 708 is a scanner than a tool for pin extracting algos.
    anyway the day You will brick a car with the most expesive OBD for DUMMIES tool will come and then You will ask same questions and will get same answer - senda dump from immobox, or ecu or dash .... don't take me wrong - all of us are using easy to use tools (obd for dummies) but if something go wrong we are ready tofinish thetask or bring damaged car to life again with help of basic seldering skills and programmers. my 2 cents....
