Results 1 to 15 of 26
    DK Veteran r.kelly's Avatar
    Default CAT ET 2015A PLUS ACTIVATION
    Hey friends,
    I have the above caption software for you with activation for free.
    No attached password.
  2. The Following 49 Users Say Thank You to r.kelly For This Useful Post:
    11margit (9th November, 2017), ahmadgrt (5th July, 2017), alawibaalawi (15th April, 2017), alberjose (12th April, 2016), bindee (24th October, 2017), Binx360 (18th December, 2018), CATMAN72 (26th November, 2016), dkbbt (23rd March, 2017), doit64 (2nd August, 2018), dp12fix (31st July, 2016), electricalcente (18th March, 2017), eliah (7th March, 2017), faridmelendez (27th October, 2016), gemini25 (6th January, 2020), hargsv (16th July, 2017), icemangonewrong (11th February, 2018), karub (14th November, 2016), kikass (16th December, 2017), Kranzy09 (6th May, 2018), lanchero (15th June, 2021), lkrasovsky (5th May, 2016), mah8050 (3rd May, 2017), manrrique29 (7th March, 2018), marcel cirozz (20th August, 2016), mick65 (24th October, 2016), PAW212 (1st February, 2017), rodypi (1st July, 2020), Rog3rD (11th July, 2016), Roy Suryadwiananda (19th October, 2016), salwan (22nd July, 2020), SAYA6081 (9th January, 2017), seal777 (28th December, 2018), sethisingh (5th August, 2018), srmosqueda (31st March, 2021), ssnoop (20th April, 2017), Tiki (6th May, 2017), ttech14 (5th February, 2017), vicente456 (21st May, 2019), Viledrake (6th December, 2017), way0end (15th December, 2017), whalla (27th November, 2017), yagami45 (4th December, 2017), yanlızkurt (16th October, 2018), zalacayn3 (25th April, 2017)
  3. #2
    Member lkrasovsky's Avatar
    Ukraine
    Thank you very much,
    Jul 2016
    Dose this work someone tell us
  5. The Following User Says Thank You to mohboub For This Useful Post:
  6. #4
    Quote Originally Posted by mohboub View Post
    Ofcourse Yes
    Helpful? Hit the thanks button
    Helpful? Hit THANK button!
    R.Kelly
  7. The Following 3 Users Say Thank You to r.kelly For This Useful Post:
    AlexGoo (16th September, 2016), SAYA6081 (9th January, 2017)
  8. #5
    Jan 2017
    Sao Tome
    how to activate cat 2015a? how to change adress mac ethernet?
  9. #6
    Quote Originally Posted by paulomandinga View Post
    Use the Networkhwdid
    Helpful! Hit the THANK button
    R.Kelly
  10. #7
    Apr 2017
    Quote Originally Posted by electricalcente View Post
    Thank you very much
    Thanks for the link. Does this work? And where can I download the 2015 version?
    Thanks so much
  11. #8
    Apr 2017
    HI
    I changed the MAC address to the number in the text.
    Then what should i put in the "serial" in SIS ID 2012? How to work this??
    Quote Originally Posted by r.kelly View Post
  12. #9
    Nov 2011
    R Kelly
    how to activate cat 2015a? how to change adress mac ethernet? Use the Networkhwdid .
    How do you do that ?
  13. #10
    Quote Originally Posted by toolking View Post
    R Kelly
    Guess you were able to solve the problem
    Helpful? hit the thank button and REP 1+
    R.Kelly
  14. #11
    Dec 2017
    Thanks so much
    Does this activation work with previous versions?
  15. #12
    Quote Originally Posted by yagami45 View Post
    Thanks so much
    No I guesd
    Sent from my SM-G925F using Tapatalk
    R.Kelly
  16. #13
    Mar 2018
    I cant activate mine because I have a dell inspiron 13 5000series windows 10 64bit and it doesn't work
  17. #14
    Quote Originally Posted by Kranzy09 View Post
    i can not download the file for some reason?
    What reason? Because the link is fine
    Helpful? Appreciate
    R.Kelly
  18. #15
    May 2018
    This comes up all the time ive done everything on the list to do
    Kranzy09
    , you do not have permission to access this page. This could be due to one of several reasons:
    1. Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
    2. If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation. Check your registered email address for an activation link.
    3. If you are trying to download files from the download section or download attachments, you are required to post on the forums before gaining access. After posting, your account will be upgraded within 15 minutes. Please don't post asking why you can't download, if you have posted, permission will be automatically granted.
  19. The Following 2 Users Say Thank You to Kranzy09 For This Useful Post:
    AZEDINOSS (12th March, 2020), INFOR3000 (25th July, 2018)
