Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 70
Thread: ashes 2009 wii
  1. #31
    Default Wii Cricket frezzes
    I too have this same problem and find it rather fustration as my game is played from a harddrive with usb loader would this solution help me
  2. #32
    Default Download won't work
    I have tryed to download but it won't let me download it any other way to download it thanks
  3. #33
    Junior Member briggs411's Avatar
    Canada
    easiest way i got this game to play was to load the game using ios223.then you have no problem creating profiles.i went ahead and created all 3 profiles.but i found that the game froze at times during the tutorials and even at loading.so after creating profiles with ios223 switched back to ios249 and have had no problems at all playing the game for the last month.
    hope that helps.
  4. #34
    Aug 2010
    Default is there any way to bypass the save profile?
    hi,
    i was able to download the file. i extracted the rar file and copied all the folders to the sd card. but when i got to data management i dont see any file to copy to the wii
    help
    jazzed
  5. #35
    Oct 2010
    Default ashes 2009
    even i face the same problem it hangs at profile loadind ?
  6. #36
    Nov 2010
    Quote Originally Posted by briggs411 View Post
    hope that helps.
    Can you explain this a bit more in depth? I'd like to get the profiles done and the go back.
  7. #37
    Canada
    when u load the game go to settings and change the ios to ios223.this should allow u to create the profiles.i went ahead and created all 3 profiles.when u done exit the game and load it back using ios249.the 3 profiles u created should be there.and u should be good to go.
  8. #38
    Nov 2010
    Starting it with wiigator, (although it is a bought and paid for PAL game - I'm in a NTSC area) I do not see the option.
    I'm obviously missing something or missed a post.
  9. #39
    Canada
    i have the game saved on my hd and use wiiflow to open it.i have also employed the same fix opening the game with CFG usb loader.
  10. #40
    V.I.P.P.T. Member
    Sep 2008
    Just off the M1
    I canr get it to work with 223 either. Im using the latest version from the 5.1 installer. Which version are you using and with which base?
    XBMC/KODI Developer
  11. #41
    Canada
    not too technical when it comes to #s so i am posting a syscheck from my system.hope the info u want is here.
    sysCheck v1.6.1 by Erik Spyder
    Region: NTSC-U
    The system menu v481 is running under IOS61 (rev 5405)
    Hollywood v0x21
    Console ID: 92623526
    Boot2 v4
    Found 104 titles
    Found 29 IOS on this console
    Found 10 IOS Stubs on this console
    IOS (revision) IOS Stub Trucha Bug ES Identify Flash Access NAND Access Boot2 Access USB 2.0
    IOS3 (rev 65280) Yes ? ? ? ? ? ?
    IOS4 (rev 65280) Yes ? ? ? ? ? ?
    IOS9 (rev 778) No Disabled Disabled Disabled Disabled Disabled Disabled
    IOS10 (rev 768) Yes ? ? ? ? ? ?
    IOS11 (rev 256) Yes ? ? ? ? ? ?
    IOS12 (rev 269) No Disabled Disabled Disabled Disabled Disabled Disabled
    IOS13 (rev 273) No Disabled Disabled Disabled Disabled Disabled Disabled
    IOS14 (rev 520) No Disabled Disabled Disabled Disabled Disabled Disabled
    IOS15 (rev 523) No Disabled Disabled Disabled Disabled Disabled Disabled
    IOS16 (rev 512) Yes ? ? ? ? ? ?
    IOS17 (rev 775) No Disabled Disabled Disabled Disabled Disabled Disabled
    IOS20 (rev 256) Yes ? ? ? ? ? ?
    IOS21 (rev 782) No Disabled Disabled Disabled Disabled Disabled Disabled
    IOS22 (rev 1037) No Disabled Disabled Disabled Disabled Disabled Disabled
    IOS28 (rev 1550) No Disabled Disabled Disabled Disabled Disabled Disabled
    IOS30 (rev 2816) Yes ? ? ? ? ? ?
    IOS31 (rev 3349) No Disabled Disabled Disabled Disabled Disabled Disabled
    IOS33 (rev 3091) No Disabled Disabled Disabled Disabled Disabled Disabled
    IOS34 (rev 3348) No Disabled Disabled Disabled Disabled Disabled Disabled
    IOS35 (rev 3349) No Disabled Disabled Disabled Disabled Disabled Disabled
    IOS36 (rev 3351) No Enabled Enabled Disabled Enabled Disabled Disabled
    IOS37 (rev 3869) No Disabled Disabled Disabled Disabled Disabled Disabled
    IOS38 (rev 3867) No Disabled Disabled Disabled Disabled Disabled Disabled
    IOS50 (rev 5120) Yes ? ? ? ? ? ?
    IOS51 (rev 4864) Yes ? ? ? ? ? ?
    IOS53 (rev 5406) No Enabled Disabled Disabled Disabled Disabled Disabled
    IOS55 (rev 5406) No Enabled Disabled Disabled Disabled Disabled Disabled
    IOS56 (rev 5405) No Disabled Disabled Disabled Disabled Disabled Disabled
    IOS57 (rev 5661) No Disabled Disabled Disabled Disabled Disabled Disabled
    IOS60 (rev 6174) No Enabled Disabled Disabled Disabled Disabled Disabled
    IOS61 (rev 5405) No Disabled Disabled Disabled Disabled Disabled Disabled
    IOS70 (rev 6687) No Enabled Disabled Disabled Enabled Disabled Disabled
    IOS202 (rev 65535) No Enabled Enabled Disabled Enabled Disabled Enabled
    IOS222 (rev 4) No Enabled Enabled Disabled Disabled Disabled Enabled
    IOS223 (rev 4) No Enabled Enabled Disabled Disabled Disabled Enabled
    IOS224 (rev 65535) No Enabled Disabled Disabled Enabled Disabled Enabled
    IOS249 (rev 17) No Enabled Enabled Disabled Enabled Disabled Enabled
    IOS250 (rev 65535) No Enabled Enabled Disabled Enabled Disabled Enabled
    IOS254 (rev 65281) Yes ? ? ? ? ? ?
  12. #42
    V.I.P.P.T. Member
    Sep 2008
    Just off the M1
    Sorted. install 223 with base IOS37 using Hermes v5.1 installer.
    XBMC/KODI Developer
  13. #43
    Dec 2010
    Default Waiting
    How long does it take for the server to catch up?
  14. #44
    Dec 2010
    do you save the profile save to a SD and then transfer it to the wii?
  15. #45
    Jan 2011
    Quote Originally Posted by hishunya View Post
    more than 25 mins ; cant not download file.. clicking on download link open a blank page.. is file missing?
    try page2, jfish posted another link.
    http://www.digital-kaos.co.uk/forums...-wii-ashes.rar
    i was having the same problem too, but that one seemd to work fine
