Results 1 to 6 of 6
    Sep 2010
    Default VW Passat CC - DTC 00003 Control Module Defective
    please help me with this airbag ECU 5N0 959 655 VW10 which has this Error:
    00003 - Control Module
    014 - Defective - MIL ON
    I tried another dump but I cant find OK dump with correct coding. This ECU has 0012338 coding.
    Is it possible to solve the problem by modification in dump or not?
    thanks for help
    Jun 2010
  3. The Following 4 Users Say Thank You to autoprzemo For This Useful Post:
    azercode (21st September, 2016), datapage (4th March, 2016), RasoRaso (21st October, 2018), vopi (20th November, 2015)
    Sep 2010
    Problem solved, thanks
    Feb 2017
    Hello,
    I have a Seat Leon with this error in the airbag module.
    how can i fix this.
    Address 15: Airbags Labels: 5N0-959-655.lbl
    Part No SW: 5N0 959 655 N HW: 5N0 959 655 N
    Component: J234__A0A VW10 HI 1916
    Revision: 21014000 Serial number: 003GHPJDWBGN
    Coding: 0012353
    Shop #: WSC 06402 785 00200
    VCID: 489F32463B72D10228-801C
    1 Fault Found:
    Freeze Frame:
    Fault Status: 11101110
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 110864 km
    Time Indication: 0
    Date: 2011.03.08
    Time: 14:59:48
  6. The Following User Says Thank You to jon187 For This Useful Post:
  7. #5
    Oct 2018
    I have some problem with airbags on Passat 7 2011
  8. #6
    Top Poster zapdus's Avatar
    Jan 2017
    Quote Originally Posted by vopi View Post
    thanks for help
    How did you solve?
    I have the same problem
    Chip Diesel
    Peugeot 206 2.0 HDI 90HP @3XX HP LOADING
    GTB2060VKLR billet
    Autotuner/MPPS/ECUDecoder/ECMTitanium ORI
