EDC17C42 Nissan Qashqai 1.6 DCI DPF Off help
Results 1 to 8 of 8
    Dec 2010
    Default EDC17C42 Nissan Qashqai 1.6 DCI DPF Off help
    Hi guys, I was wondering if anyone can help me with finding manual switch solution for DPF off in EDC17C42 ECU from 2012 Nissan Qashqai 1.6 DCI. DPF has been emptied, sensors are plugged in. Going into limp mode at 3000rpm with DPF pressure sensor fault. Perhaps someone with swiftec could help?
    Any help would be appreciated!
    https://www.dropbox.com/s/oiqzrpd1oo...6%20130PS?dl=0
    Best regards,
    Lee
    MPPS Standalone Master, Magpro Base + X17, Dimsport New Genius, Piasini, Galletto V53, Kess V2, K-Tag, Trasdata remapping tools | OP-COM, VCDS, Fiat MultiECUScan, Ford F Super, Renault CAN Clip V124, INPA/NCS Expert + others.
    Dec 2010
    Babos's Avatar
    Mar 2012
    if you have damos share to we try to help you faster.
  4. The Following 3 Users Say Thank You to Babos For This Useful Post:
    jonasgsxr (20th September, 2022), teamtuner (22nd November, 2015)
    Dec 2010
    I have attached damos a2l + hex
    r9m damos.rar
    If anyone can help with locations in damos then I can transfer to my project .
  6. The Following 6 Users Say Thank You to poxxxy For This Useful Post:
    Gery (29th December, 2015), jonasgsxr (20th September, 2022), Moldovan1 (3rd August, 2017), Novik_UA (6th May, 2018), omino (6th January, 2019), tom2222 (29th March, 2021)
    Top Poster slave's Avatar
    solution of beta swiftec you know if everything is ok...
    GARAGE0864
  8. The Following User Says Thank You to slave For This Useful Post:
    achraf11 (15th May, 2016)
  9. #6
    Dec 2010
    thanks Slave, will take a look at file when home
  10. #7
    Aug 2014
    Quote Originally Posted by poxxxy View Post
    r9m damos.rar
    does anyone have REAL EDC17C42 damos? all I found is named like that but then it's Siemens SID305 ...
  11. #8
    Dec 2011
    fap off nissan plz
