Results 1 to 7 of 7
    Default Renault Megane 1.6 2002 UCH Clone
    Need some help with Renault immo..... I have two renault UCH boxes here. One is broken, the other one is ok. Both has identical numbers.
    The car doesn't start with the new UCH because of immo. Can I move eeprom over from the old box to the new one to transfer immo data? IF that is possible, where is eeprom located?
    Thanks for the help in advance
    - L
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    In my immobox...
    Motorola MCU 1k20c
  3. The Following User Says Thank You to lupu_sandu For This Useful Post:
    technic (3rd December, 2015)
    Enough to swap MCU? No coding in eeprom to be transfered?
    Moderator
    PremierD's Avatar
    Jun 2009
    Just a guess here mate .. but doesn't the MCU contain an eeprom portion .. ?
  6. The Following User Says Thank You to PremierD For This Useful Post:
    I have no idea... Never done these before. If that is true, then MCU swap would be enough I suppose
    (Theoretically it could have both virtual eeprom, eeprom in MCU and external i2c/spi i guess )
  8. #6
    Nov 2012
    greece
    only change MCU
  9. The Following User Says Thank You to jokas For This Useful Post:
  10. #7
    PierreTheron's Avatar
    Centurion,South Africa
    Or read eeprom area from mcu and tranfer it .
    You can use UPA-USB/X-Prog
