I use Autobouquetsmaker a plugin available in the plugins menu, once installed do the following via the remote;
? Menu-setup-service searching-ABM-Delete Bouquets, this will remove your old fav list
Menu-setup-service searching-Providers to the following;
? Freesat -No
? Sky ROI -Yes
? Sky ROI Area-ROI HD
? all other Sky ROI-No
? Sky UK-Yes
? Sky UK Area- Scroll right to get ‘your area’ custom ie mine’s Scottish East Custom this will replace all none working HD channels with their working SD conterparts
? Sky UK FTA only-No
? Sky UK Gen main Bouquets-Yes
? Sky Uk Gen Section Bouquets-Yes
? Sky UK swap channels-Yes
? All others-No
? Menu-setup-service searching-ABM-Hide Sections, select what bouquets you want to hid (I select all the Sky ROI bouquets)
? Menu-setup-service searching-ABM-Start Scan ,this will add all the relevant channels for your area
You will have to add Setanta HD, Eurosport 1 & 2 HD to the 'Sports' bouquet
? Select ‘fav’ on your remote then the green button then select 28.2e
? Scroll thru the channel and find setenta HD
? Press ‘menu’ and then ‘add service to bouquet’ select the ‘sports’ bouquet
If you do regular ABM scan you will have to transfer those channels everytime, way around this is to place them into you 'Fav' bouquet
