Results 1 to 3 of 3
Thread: a1278
    Mar 2012
    GB
    Default a1278
    hi i need reset efi bios paswword from dump for probook a1278
    Salut,moi aussi j'ai besoin de r?initialiser efi bios paswword de dump pour mac bookpro core 2duo a1278 annee 2010 merci.
    Jun 2017
    US
    You can use the script in the link below on a linux environment to scan for the lock and remove it. Also you can remove it manually with a hex editor, but the scan script has never failed me.
    I have manually removed the pin in this one but never have attempted it before. It may or may not work. Just use the script if you want to be sure.
    Script to remove pin
    https://ghostlyhaks.com/blog/apple-e...ssword-removal
    Details on on region to hex manually
    https://ghostlyhaks.com/blog/blog/hacking/18-apple-efi-bypass
  4. The Following User Says Thank You to darknezz19 For This Useful Post:
    berkcan (9th August, 2018)
