Good job on most models.
Some recent (2015+) does not yet support.
Land Cruiser 200 2015 yes.
Old vechicles (early 2000) little treat.
You can check with manufacturer.
javyb (3rd January, 2016)
Up-s-s!
Of course - vehicles.
Most base Toyota stock dumps allows CAN-bus without removing Ecu.
someone have infos about another tool from ukraine who work only by obd2 kline and can ?
internet is required to download original file visibly..
if someone tested it and know price ..
thanks!
hello m8 what is this model ? thanks
There is a software that can be used with Tactrix OpenPort to make ecu id and then to write with Toyota Ecu Flasher by obd
Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
POPS & BANGS (Schubabschaltung, Crackles) on allmost every petrol
it can write too visibly not only id
moky (3rd June, 2016)
toyota lexus flasher cannot read 76F0023GD and 76F0004GD mcu... any one know what tool can read it??
bitbox and pcmflash can read
moky (4th June, 2016)
You sure about read?
He not read but download flash and then write only.
vokinn (21st June, 2016)
hello
yes it is good tool, best tool for read write toyota ecu. after 2015 some ecu can not support this future will updated.
exmp- Toyota Camry 2015 do not have ecu reading point.
someone use open port 2 chinese clone with mmc2 ? or too risked?
