Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
  1. #16
    Jan 2016
    Clusters, i have converted into miles in the DIC and then disconnected and changed the faceplate and when i put it back it goes back to KMS
    I was able to use the EEPROM Clip and I backed up the KM's original bin and I put a BIN file from a 2007 silverado from here and it worked. I just edited the mileage on the OBD and it worked very smoothly. Was very tricky getting that eprom reader clipped on tho.
  2. The Following User Says Thank You to hero112 For This Useful Post:
    clusters (6th January, 2016)
  3. #17
    Jan 2016
    Now my next question is, I have a 2008 Ram 3500 Diesel, I am able to save my bin right one my USA Prog but it does not have an option to use it as a recovery file. So is the 08 ram the same thing where I have to find the EEPROM or is it another connecter? I have a bunch of the connectors and pin adapters it came with. I also found a bin on here but I have no way to figure out how to put it back on there
  4. #18
    clusters's Avatar
    Mar 2015
    Canada
    Quote Originally Posted by hero112 View Post
    I stand corrected then and they must have changed the strategy in the clusters in 2007 and it is stored in volatile memory. Thanks for the info.
  5. #19
    Jan 2016
    Any suggestions on the 2008 Ram 3500?
  6. #20
    clusters's Avatar
    Mar 2015
    Canada
    Sorry, no.
  7. #21
    Jan 2016
    Have you ever programmed any of those? If they were to be programmed on the bench, do you use like one of the pin connectors or do you an eprom reader?
  8. #22
    Jan 2016
    can anyone help
