Results 1 to 15 of 23
    Nov 2015
    Default Help with component protection removal
    Hello to all!!! I have a problem with component protection removal and hope someone can help. Today I tried to adapt a restyling dash on a 2009 audi a4 8k with no success. Connected the FVDI selected component protection, generation 2, instrument cluster, the program connected to the clster just fine and made it virgin, loaded the confdata from the 8T0 907 468 gateway 25640 eeprom but it fails to set the component protection, it says that maybe the confdata is from another car. I've tried to read the 25640 4-5 times with 3 different programmers but with no success. Has anyone ever experienced something like this???
    Thank you!!!
    Nov 2015
    I thinck I'm not reading the gateway correctly. I have Carprog, UPA-USB, X-Prog and Minipro. Read it with Minipro and X-prog but the files are not identical. Is the 25640AN the correct memory to read?
    Nov 2015
    Update. Correct me if I'm wrong, I think thre whole thing didn't work because the cluster is from a 2013 car so FVDI can't adapt new parts, is that right??? Now the big problem is that the cluster is allready made virgin and not even ODIS can do it. Does someone know a way to make the cluster back to the non virgin status??? It has a 95320 eeprom taht I have no problem to read or write, maybe writing the dump from a non virgin cluster and adapt it with ODIS afterwards???
    Thank You!!!
    Jul 2013
    Philadelphia
    Hi I have used abrites avdi for it dump from gateway... After made it virgine loaded dump and its took like 10-15 min done works good.
    It was 2011 audi q5 and swap cluster from 2014 model with black white display. Just yesterday I swap again cluster from 2010 but with colored screen again works well. The only no luck was with ac climate control error like yours
    Jul 2013
    Philadelphia
    Dump readed from gateway with orange 5
    Nov 2015
    Unfortunately it's my tool that does not do the job properly, I tried all the scenarios, currently I have 3 clusters and 5 gateways at home, nothing seems to work!!
    Apr 2013
    Stefyhgs you solventi this problem?
    Aug 2015
    Quote Originally Posted by stefyhgs View Post
    Thank You!!!
    I know this problem if cluster was made virgin with avdi odis cant remove cp anymore.
    Also i had this problem on ezs.
    So it is better to use just odis and forget avdi solution.
  9. The Following User Says Thank You to offsystem For This Useful Post:
    tiguan (24th July, 2016)
  10. #9
    tiguan's Avatar
    to use this Odis offline to remove cp ???
  11. #10
    Aug 2015
    Quote Originally Posted by tiguan View Post
    No just online
  12. The Following User Says Thank You to offsystem For This Useful Post:
  13. #11
    peko's Avatar
    so no way ?
  14. #12
    Apr 2016
    hi mate the dump from the 25640 in gateway module must come from the car you got the dash from, otherwise it will not work. hope that helps. so if you had the gateway dump from the same car you got the clocks from maybe you have a chance todo cp or re adapt.
  15. #13
    Aug 2016
    use odis engineering mode to flash the dasch. no online needed
  16. #14
    Sep 2008
    How this can be done?
  17. #15
    Jan 2016
    If you flash with ODIS eeprom will change also and I think it would not be virgin anymore than you'll be able to do CP with ODIS ONLINE.
