Results 16 to 30 of 37
Thread: INMO YAMAHA R6
  1. #16
    GB
    Quote Originally Posted by zyjekrc51 View Post
    hi
    pass PM
    AND CLEAR YOUR BOX - IT IS FULL !!! I CAN'T SEND YOU A MESSAGE !!!!
    Hello friend cleaned the box.
    thanyou
  2. #17
    Apr 2012
    London
    HI ANGMAR
    I still got same message from system: The following errors occurred with your submission
    • angmar has exceeded their stored private messages quota and cannot accept further messages until they clear some space
    so could You check again if Your PM box has space for recieving new messages? or just send me Your skype on email
    could You send me ECu number?
  3. #18
    GB
    HI ANGMAR
    Cleaned try again, forgive so much trouble
  4. #19
    Apr 2012
    London
    no problem
    PM has been sent
    WHAT is this ECu Serial Number?
  5. #20
    GB
    no problem
    PM has been sent
    2C0-8591A-01
    112100-5820
    12V TBDF21 DENSO
  6. #21
    Apr 2012
    London
    if it is 2C0-85951A-01
    You can use my ECU file - pass same as before
  7. The Following User Says Thank You to zyjekrc51 For This Useful Post:
    angmar (14th January, 2016)
  8. #22
    GB
    I try and comment , zed bull only generate a chip for start , not have possibility for master or slave.
  9. #23
    Apr 2012
    London
    so please send me data from transponder generated on zedbull - I will check if it is master or slave key
    Because I haven't got zedbull please let me know how ZED BULL works - is ZEDBULL generating TPX2 transponder from yamaha's aerial dump ?
    or
    is it generating 4D transponder and modyfying aerial eeprom dump ?
  10. #24
    Apr 2012
    London
    ....any update with Your problem - let me know
  11. The Following User Says Thank You to zyjekrc51 For This Useful Post:
    angmar (18th January, 2016)
  12. #25
    GB
    or
    I loaded the file aerial zed bull, can not be programmed TPX2 says programming error, unsuccessfully.
    Try in 5 differents transponders
  13. #26
    Apr 2012
    London
    so ZED BULL is only generating TPX transponder or You can also prepare 4D transponder and load it to DUMP?
  14. #27
    Apr 2012
    London
    if You want I can send You programed transponders 1x Master Key + 1x Slave Key
  15. The Following 2 Users Say Thank You to zyjekrc51 For This Useful Post:
    angmar (18th January, 2016), bearheroes (29th April, 2017)
  16. #28
    GB
    Hello friend recently updated firmware v 5.35 zed bull, now programmed TPX2
  17. #29
    GB
    or
    Hi I send the data generated by zedbull TPX2, you could show me which is the master and slave?
    Same pass
  18. #30
    GB
    Quote Originally Posted by angmar View Post
    Same pass
    pictures key red and black
