i dont think abrites are going to help with log files from a clone FVDI , though FVDI might have an engineer who deals with support in china
hi mate. I just had the same problem with a 2010 berlingo. did you get this sorted in the end? if so please let me know so I can sort mine out. my customer is very angry with me
many thanks dave
the poor are the teachers who work with the Chinese clones and then try to be helped on various forums.
dk forum and one of the best but Rants etc healthy people what to do
not only help help help
because no one does not try to help support chinesi
Peugeot 407, Siemens BSI, fvdi couldn't read pin. No damage. I read flash and eeprom with x-tool and calculated pin from dump with a different softwares.
To repair your JC bsi try to read it with fvdi on bench, it might me in boot mode in some cases.
Its not true my friend before trying to read be sure you hooked a good charger and remove headligt an swipers fuse it has to be 13v then read.and it wil be ok . when voltage is dropped com is lost i my self read a JC from a peugeot 607 2006 without any problem didnt try newer models what i understaand is that to do it right follow the instructions carefully.what the most of us dont do.
in your case you have to change the BSI Johnson Control with another and you have to empty (blank) st eeprom 95128 and do a manual learning with lexia pps diagbox and for the pin code you can read it from the old eeprom of your bsi damaged with a single programmer ......
what if you off economy mode by lexia/pp2000 before read ???
Yes. It's all BAD because car goes into economy mode while read...
hello , i have same problem whit same bsi.
966405878002
BSI04EV K01-00 031109
V05.01
BOOT 28120836-4
HARD 28119246-2C
short story, samo one before me try to read pin to program transponder (all keys lost) and kill car wipers fuse on lights on , so bsi in boot mode , no ignition no communication at all . can someone give me wiring diagram for read bsi on bench ,i use this http://www.digital-kaos.co.uk/forums/showthread.php/464527-Peugeot-407-BSI-JC-need-flash/page2?highlight=Johnson+control+BSI+fvdi but not work for me
to try to leave boot mode whit lexia , and try to read pin and program new transponder.thanks in advice and have a nice day
Post software signature from bsi
flash its dead
better say you kill bsi
will help you here in both case
I personally killed them a lot jci
Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
georgiev86 (24th June, 2020)
see in this or another folder demage flash number if you can faind and post
C:\Documents and Settings\PC\My Documents\ABRITES software for ID 1715C7
Darek90 (3rd July, 2018)
Hi, someone could help me I have a Peugeot 308 with 74268kn and I need 45100km. THANK YOU
dzamine670 (31st January, 2020)
