Page 9 of 18 FirstFirst ... 4567891011121314 ... LastLast
Results 121 to 135 of 260
  1. #121
    Jan 2016
    thank for you
  2. #122
    Jan 2016
    silnik nie działa - praca 1s - 58 cut
  3. #123
    Shmortz's Avatar
    in the middle of nowhere
    here you are, cut pin58
  4. The Following User Says Thank You to Shmortz For This Useful Post:
    art13 (11th December, 2017)
  5. #124
    Jan 2016
    perfectly !
  6. #125
    Feb 2014
    Default Please help with Renault Clio immo off
    I have Clio 1,4 16V and car wont start with solution from ecuvonix.
    You are my last hope.
  7. #126
    kazoula55's Avatar
    Sep 2012
    Quote Originally Posted by dadal View Post
    willem can do it, i think you had bad pins contact.
    this dump is 100% OK
    Pls push Rep button and dont forget feedback
    Please rar pasword.
  8. #127
    Jan 2016
    Could someone help me with mine please? Its sirius 32 no can. Thanks Flash attached read by Ktag. I have a solution but engine only works for 1 s and central locking stopped reacting to remote.
  9. #128
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by lobsterosxxx View Post
    Here your oFF file.
    Remove resistor or cut pin 58. See picture
  10. The Following User Says Thank You to lion0304 For This Useful Post:
    lobsterosxxx (21st January, 2018)
  11. #129
    Jan 2016
    Quote Originally Posted by lion0304 View Post
    Here your oFF file.
    password would be helpfull thx
  12. #130
    Jan 2016
    Here your oFF file.
    Doesn't work. Starts twice then doesn't plus remote central locking died
    Wysłane z mojego WAS-LX1 przy użyciu Tapatalka
  13. #131
    Jan 2016
    Sorry didn't try your solution as no pass provided. Wrong post.
  14. #132
    shafo's Avatar
    Apr 2016
    Sa
    Default CLIO sirius 32n 1.4 16v with ac
    hi guys if someone can please help with a tested file...i think i will destroy this ecu if i remove flash again
    attached ori read
    1.4 16v with aircon
    Please add rep if I help you
  15. #133
    antwnhszr's Avatar
    macedonia is greek....
    Quote Originally Posted by shafo View Post
    attached ori read
    1.4 16v with aircon
    good day dear friend....
  16. The Following User Says Thank You to antwnhszr For This Useful Post:
    shafo (26th January, 2018)
  17. #134
    shafo's Avatar
    Apr 2016
    Sa
    Quote Originally Posted by antwnhszr View Post
    thank you my friend ..can i have pass please
  18. #135
    Jan 2018
    UK
    Hello ! I have a Megan 2001 with Sirius 32N ECU. Car did't start, immo light is blinking. I think it's because of multifunctional module. I removed it and found corrosion inside.
    Can anybody help me make imMult_PE2_connector_corrosion.JPGmo off ? Thanks in advance !
