[Quote = cutiutza; 3006417] should Immo off please help ... and sorry if I put same DK twice..in problem, all the best for everyone [/ QUOTE]
Hello!
go to PM
you need to cut wire 58 FOM ECU ...
sorry .. this is .. file immo off pass is the same
Hello!
go to PM
hy,this is dump with immo off?she is not ask any pasword
i willl put the dump in ecu in 10min
the dump is not ok..is the original with no immo,is the same plese immo off thanks
i try the senond one with th patched,and is not start the carr
not working my friend,the immo line is cut..pin 58
hi all inned immo off ecu clio 1.2 S110115000B 8200162378 thanks
brahimdyag10 (17th April, 2017)
I m not sure but I think this is on ecu Can-Bus system ( ecu number S110115000B ) check it ecu socket if pin 58 has wire or not ?
canbus ecu need emulator, but send your dump we try first to make immo off without emu.
Dear mate lion0304,
please i need your help with renault clio 1.4 without AC...I have tried so many files and sw to make it immo off but it did not work...i would appreciate your support so much.
Thanks in advance.
cut wire 58 from ecu
ecu repair (10th May, 2017)
Thank you mate for reply but i am sorry the car did not start....I think that this car needs an emulator to start...on the other hand i could see here on DK some mates who can modify the file to start without emulator and i am still hoping that they may see my post and be willing to help...
Thank you again for your time
Thank you mate but again i am sorry it did not start...actually the eprom pins are getting weak from soldering and dissoldering...i do appreciate your support althought it did not work but it is enough that you have tried...Thanks.
