HI, Someone read SD cards from mini900. I need ver. 1.13.
update to 1.23. 2.15 4d copyng fixed 46 copy okay sorry cant test 4c has i have no chips to test so if you have version 1.20 update to this to fix this issues or if you have version 1.13 just keep this do not forget to say thank you.
For me.
Updating to 2.5 Sw on PC. Have some error.
It just bounces in a circle.
Download SW, shut down start up and download again the same 2.5.
If I use older SW it does not connect to web.
I have 1.22.2.15 from earlier. Trying to update to 1.23.2.15
Not possible to do further update on the tool because of this.
Please someone uploade mini900 updater v 2.5
If the program will update around, change the language to Chinese
after latest update, still not copy 4D
DK- The Bogs Dollocks!!!
NEVER SAY IT CANT BE DONE!!
The thanks button works wonders!!
DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
brief report from Indonesia market in regards to CN TOYO..
~ Failed on Avanza G
~ Failed on 2008 Fortuner G
report is from my fb friends.
as i said in previous the developer of this tool need to check the updates on this machine and test that can copy after as been updated not worse than before the update software is a joke please stop buying this tool till all this issues are fixed also the 4 d copy
works on last update but you need to put cn chip near bottom of coil reader as is very weak what is the point of selling obd adaptor if these issues are not fixed yet with the mini cn900 .
all people of the world please flood tjecu email with negative opinions about this device.
and do not buy this s..t
click "?" button you will see email.
solitaire (24th January, 2017)
click what ? ?
pm me email plz
igorr (24th January, 2017)
when you open software updater there is "?" green button upper right corner. click it, there is tjecu email.
note from aliexpress ys-01 chip:
ps. CN5 copy work fine
Emailed frustration hopefully fixed soon
the developer of this tool should be ashamed cant release a update that works and fixes the copy problems and the update tool is a joke if you have version 1,13 do not update and stop buying this tool till problems solved never mind the obd adptor
if cant copy 4c etc what is the point .
