just bricked mine than followed instruction from member and updated to 1.13 thanks for instructions and photos all working updated to latest .
cn900mini can't work with original TPX transponders?
Iv used tpx4 ok
HeXeN (3rd August, 2016)
have you used tpx4 for colllecting data sniffing or to copy directly to it thank you .
depends on the car, for Mitsubishi need to sniff, but Honda and Nissan no, at least the ones I haved done.
I asked about COPYING into original TPX transponders, they are better than CN and price isn't big difference here where I order but CN from china they come locked and other s..t happens (weak signal etc)
Automat (14th August, 2016)
Automat (14th August, 2016), dimet (27th December, 2016), Fernandowap (4th August, 2016), godfathertre (4th August, 2016), HeXeN (4th August, 2016), Tariel (5th September, 2016)
I have always used the cn900 to sniff not done to many but those I have worked into tpx4
Anyone try to clear byte with this type?
anyone tried a TPX5 with the mini?
I got my mini900 (ordered a cn900 and was sent an nd900 'mini900').
It can read chips, successfully decoded id46 (with sniff data) and 4d but can't seem to write anything
tried generating an id13 from a t5 and it couldn't even write that
seems to have no problem reading but impossible to write
I have updated to the latest software (nd900 not cn900 software)
Anybody successfully used an nd900? very dissapointed, thought it would be good as a portable device for the simple jobs
What chips you use to write?
I have the same ND900 mini, test with PCF7936 cannot read when PCF in the key shell, need remove off and put near antenna.
The antenna is weak, so i modifie the hold that make the key nearest antenna.
Now is is OK
