Page 32 of 36 FirstFirst ... 2227282930313233343536 LastLast
Results 466 to 480 of 527
  1. #466
    Feb 2014
    In Autokeys store there are both options - OEM and Aftermarket. The OEM is the one that mini900 can use with the latest firmwares.
  2. #467
    Dec 2009
    scotland clydebank
    just buy a handybaby nothing works on mini cn900 and zero support from developer i have this mini cn 900 the only thing that was working the id 46 copy does not work anymore and latest update why does the developer not make one chip and this will stop this
    nonsense
    of buying 4 different chips i do not trust this tool for nothing last time tried to clone a vauxakll key in corsa tried 20 times would not collect data tried with handybaby job done .
  3. #468
    Feb 2014
    It's working fine with original CN chips. Only problem I see is with ID48 - if you try to decode a key it will damage the original transponder. Tested on two FIATs already...
  4. #469
    Dec 2009
    scotland clydebank
    good way to mess up customer keys than to obtain or pull pincode and make job ten times harder for locksmith there are no original cn chips most of chips you buy for this tool is hit and miss the id 46 that worked does not work on cn3 or tpx4 on latest version
    are you by the way affiliated with developer of this tool if so tell him to try the tool before releasing software so we do not mess people cars .
  5. #470
    Feb 2010
    Essex/East London Boarder
    I use CN5 on mine as cn2 doesent work.
    I done a couple of 1d46 and only needed one sniff of data onto cn3.
    I have just got a Handy Baby because of ID48 and it was a god deal from another lockie .
    I Like it so far .
  6. #471
    klaudio's Avatar
    Jul 2016
    My works fine with 4d ford and toyota, will copy smart key to transponder, ID46 no problems, 4c all good, after reading on id 48 I will not try it, , maybe I got lucky with mine and I'm afraid to do an update as I hear they are issues after, paid for itself several times, will be buying handy baby next, is always good to have more than less for back up.
    ​Some people just want glory instead of acknowledgment.
    Thanks and reputation is earned, not ask for.
    Have a nice day.
  7. #472
    Feb 2014
    VVDI key tool might soon be a much better alternative. HandyBaby too expensive for what it does, for me.
  8. #473
    Oct 2017
    anyone know how to active toyo key obdII device and get code.as my seller is not responding my emails.
  9. #474
    Feb 2017
    UK
    I have problem with this tool as version 1.34.2.19 don't work for decoding id46 "Decoding failed" is it something wrong with upgrade, software. Can someone confirm how many micro sd card needs the tool? I opened to check if it's everything ok with the connection and I saw there is a 5 ports and I have just one micro sd card I think maybe with the latest version need more sd cards or put in a different socket ? Thanks
  10. #475
    Feb 2017
    UK
    Quote Originally Posted by alkazav View Post
    Does anybody have solution to restore old firmware and software on ND900 mini because afther update to version Software 2.9 and Firmware version: 1.34.2.19 my device cant recognized ordinary ID48 and cant clone ID46 and ID60 on old CN1 and CN3 chip (i have them about 20 pieces) although I could that before update. Crap company and crap device.
    Have you got id46 decoding problem or just copying with the latest version?
  11. #476
    Apr 2012
    Someone know where to buy Touchscreen for CN900 Mini ?
    Trimis de pe al meu VTR-L29 folosind Tapatalk
  12. #477
    Feb 2010
    Hi guys just a quick one.
    Used my little red box of tricks yesterday tried to clone ID46 Citroen van 63 plate .
    Sniffed data 6 times tried to write on 4 different chips .
    After try all areas of reader managed to get one to write sucess .
    No start from van done it again still the same .
    This did do cloning ok before last update so think its a problem there?.
    also having problems now cloning id 60 to cn5 as cn2 never worked but cn5 did .
    Looks like they have screwed it up.
    Mine is the Six window display version not four.
  13. #478
    Feb 2014
    All have 6 buttons after they are updated to latest version. Are you using good CN chips - original from the last batch from TJECU factory?
    Did you try to write it on an TPX4 to see if car will recognise it?
  14. #479
    igorr's Avatar
    Aug 2010
    Quote Originally Posted by autoTkey View Post
    cn3 are weak nead to be closer to car coil and it will start
  15. #480
    Feb 2010
    Quote Originally Posted by igorr View Post
    Thanks for reply guys .
    The chips i use are from same batch as previous (3D group).
    My friend has four window version all is ok dont think he has ever updated his .
    I also trided chip as close to ign as possible still non start.
    As i said i have handy baby so think this little tool maybe headding for the back of the draw,,
    Thanks all
