Tried it on Fiat Stilo 2005 - it killed the original transponder. Had to cut and program two keys instead of one...
What do you mean - what problem?
Just need to be stubborn on the update button and push it until it has no more updates to add... In some parts of the update process your tool might look like it is bricked(not responding to the update tool) but just detach the cables from it, turn it off and back on again, restart the update tool and push connect/update again. If still refuses you can try to remove battery as well but be careful not to interrupt an actual going update progress. Give it enough time on each step.
The whole process can take up to 1 hour depending on the servers.
By the way I was "brave" enough to try and copy a Passat B6 ID48 ...or should I say dumb? It surprised me it sniffed the data from quite far away, but of course it couldn't decode it Tried few times and each time it replied sniff data was not enough.
Weasel3 (23rd November, 2017)
Was there no redcovery button showing .
IE write orignal data !
No such button noticed. Transponder wasn't unlocked and didn't show signs of data alteration.
After the data collection step it gives a black screen with some white and red letter writings(don't move the key, etc...). I clicked on the black screen to start calculating and after few minutes Mini900 turned itself off - not just the screen but the whole unit. Tried two more times and gave up on the idea. Then noticed car doesn't recognise the transponder anymore and didn't want to program it too. So prepared two transponders and programmed all by OBD2 and done testing the ID48 functionality of the Mini900.
Hi i have question i have tmini900 with old fw i will update but in tool sey no need new fw . Ok i need bay update but on cn900mini site only updte for 249usd !?New device with5.14fw coast 175usd . i cant find eny contact for company on sites. Have got evrybody contact for company thanks
On my device after puch update is Firmaware is latest no need update. My FW is 1.13 maybe for my SN isnt update or need pay 240 usd for it ,but for me is better bay new device with latest FW and old give under table :-) Thanks
CN900mini TEJCU is another company as TJECU mini900 ?
I'm not sure but before it was considered that CN900mini is a clone of the ND900. So you maybe have bought the cloned tool.
CN900 mini is also an original device by Tjecu but just named and sold by different company (Tjecu is the OEM of CN900 mini) while ND900 sell by Tjecu company directly.
When updating, you must use their own update tool/software though
You cannot use ND900 update software for updating CN900 mini and vise versa which i could not understand why but it works fine if you use the correct one to update.
Download the update software for CN900 mini from here: http://cn900.net/
From what i heard, ND900 is originally made for China market while CN900 mini is for international market.
Does anybody have solution to restore old firmware and software on ND900 mini because afther update to version Software 2.9 and Firmware version: 1.34.2.19 my device cant recognized ordinary ID48 and cant clone ID46 and ID60 on old CN1 and CN3 chip (i have them about 20 pieces) although I could that before update. Crap company and crap device.
Solution has already been discussed here few months ago... Buy new original CN transponders. The only solution.
i have problem with id48 reading too ...i dint try cloning 4d o 46 ...with 1.13 worked
Problem with ID48 is known too - machine can't read the oldest ID48. Called "Magic 1". With "Magic 2" there are no problems.
yep problem with magic2... passat 2007 no read
