Page 28 of 36 FirstFirst ... 182324252627282930313233 ... LastLast
Results 406 to 420 of 527
  1. #406
    Nov 2014
    Hello colleagues, version 5.18 that appears in aliexpress, is it good or recommendable ???
    Has limitations ??
    Thank you very much
  2. #407
    Aug 2010
    Down Under
    Quote Originally Posted by Duracell2 View Post
    is it possible to clone ALL ID46 chips ? I need to clone ID46 for OPEL(Vauxhall)/Peugeot/Citroen ? Will it work ?
    I still using version 1.13 and cloned few Opel 46 without hassle.
    Read about problem after updated so have no intention to do so
    There are "no good" twice when I could not sniff any data from an Audi 2010 and a Chrysler 300C with a push in fobs (FOBIK key)
    Just thinking if I can copy the chip and insert into a dummy fob it may do the job ... maybe not... but cannot clone it anyway
  3. The Following User Says Thank You to bigkey For This Useful Post:
    Duracell2 (27th June, 2017)
  4. #408
    Jun 2017
    If somebody managed to clone 48 chips?? I have the latest version 1.30.2.18 and will not clone
  5. #409
    Duracell2's Avatar
    Apr 2017
    I bought the cn900 mini and appropriate ID46 chips. (5.5 € /piece)
    Cloning worked for Astra H and Peugeot 307
  6. #410
    Jul 2017
    Quote Originally Posted by sv2hqx View Post
    you dont read
    you can copy 4c to cn1 chips
    4d to cn2 or cn5 chips
    id46 to cn3 chips
    First i ordered cn2 chips.
    1pcs from France and 5pcs from UK. With firmware 1.30.2.18 i can`t copy my key (4D60)
    today i received another 5pcs cn5 (YS31) chips (same seller from UK) and now it was possible to copy my key.
  7. The Following User Says Thank You to TomCat2 For This Useful Post:
    Recoder (26th July, 2017)
  8. #411
    Feb 2016
    Anyone with a solution for the sub firmware 2 update failure on early models?
    keflavik
  9. #412
    Dec 2009
    scotland clydebank
    the mini cn900 ia a joke latest update only id 46 works the update procedure took me 3 days if you have version 1.13 do not update zero support from developer why not bring a way to downgrade software on machine only use for reading and use the jma handy
    baby superb tool and now 1 chip to copy all king chip just introduced and copy id 48 fast .
  10. The Following User Says Thank You to godfathertre For This Useful Post:
    Automat (3rd October, 2017)
  11. #413
    Feb 2010
    Essex/East London Boarder
    My CN900mini could not copy 4d 60 or 63.
    Tried as suggested by TomCat2 onto a CN5 and perfect .
    Will tryid46 when i get a chance .
    HTH
    My version is 1.30.2.18
    Quote Originally Posted by godfathertre View Post
  12. #414
    Jul 2017
    Hi to all. When decoding id46 i got sd1 error. Maybe any one knows the solution?
  13. #415
    Dec 2009
    scotland clydebank
    i mate nothing surprises with this tool try to collect data from opel corsa tried 9 times would not collect used my handy baby key programmer first try decoded and all done the developer of this tool should be ashamed why make a tool that very little work
    and zero support from developer buy handy baby key programmer and you will not be disappointed i only use my mini cn900 mine for reading chips nothing else .
  14. #416
    Duracell2's Avatar
    Apr 2017
    when sniffing on my Astra H, I noticed, that the data is collected during putting the key INTO ignition, not during turning the ignition.
    Maybe this is also the case with your Corsa.
    I successfully made the key for Astra H with the CN900 mini.
    Maybe you give another try, and come with results.
    Best regards.
  15. #417
    Jul 2016
    CN900 Mini Key Programmer 1.32.2.19
    Add Toyota 71,74,8A Smart key ADD and DELETE via OBDII
    Add Toyota 71,74,8A Smart key all keys lost programming
    Add Toyota 8A smart key RENEW
    Add 8E Bank Data read, CS crypto Programming, CS Unlock
    Add Partial 48 Decoding and Copy. Shoddy 48 identification
    Add HITAG VAG identification
    I tried renewing 8A fob with no luck
  16. #418
    Duracell2's Avatar
    Apr 2017
    "Add Partial 48 Decoding and Copy"
    I have updated it to latest version (1.32) and will today test a partial decoding function on some VW.
    Will come with results soon.
  17. #419
    Duracell2's Avatar
    Apr 2017
    Here are the results of the new "Partial 48 Decoding and Copy" function tested on VW Golf MK 4:
    You have to update to version 1.32
    Decode button is now working. After pressing the decode button, you have to sniff data from ignition lock of the car.
    After that,decoding starts, and lasts for AT LEAST 20 minutes. You can see at the picture, that decoding is already 20 minutes in progress.
    After that I left it for another 40 minutes. When I came back, the decoding was finished.
    As you can see, the Secret Key is visible, but it shows "xxxx xxxx"
    I don't know what the meaning of those "x"-es is.
    After the decoding, the function "Unlock" is working.
    Also "copy" button is shown for coping to CN6 chip. I had no CN6 chip to test.
    The problem here is that decoding time is very long. Almost 1 hour.
  18. The Following User Says Thank You to Duracell2 For This Useful Post:
    autoTkey (31st August, 2017)
  19. #420
    Oct 2015
    USA
    I tried Toyota Smart key 71 all keys lost and no luck also.
    Failed to read file.
