Results 1 to 4 of 4
    DK Veteran chris31560's Avatar
    wigan
    Default help pictures wont transport
    hi guys, I have recently bought a android smart phone thing is when I connect the cable the the phone then to the comp to upload pictures it says, usb device not recognized, no matter what port I connect to says the same.
    any help would be great...cheers..chris.
    A LITTLE THANX GOES A LONG WAY
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    I assume other usb devices connected are ok. Is it the correct usb phone cable? Have you went into phone development options via settings and check usb debugging is on. hth
  3. The Following User Says Thank You to DOUGALMCD For This Useful Post:
    chris31560 (4th February, 2016)
    wigan
    cheers bud, it was the USB cable, would never of thought of that..cheers..chris.
  5. The Following User Says Thank You to chris31560 For This Useful Post:
    DOUGALMCD (4th February, 2016)
  6. #4
    Feb 2017
    is the cable sucks? I have this problem before and the reason is the bad plastic cable. That's why I use metal piarmor cable currently and no more issues happen.
