Are you referring to certain Movie channels by any chance? I've come across quite a few 5402's having issues with them, usually changing ports on LNB or replacing LNB altogether fixes it.
Hi, I have a problem that it may be considered borderline with the rules of the forum, anyway I try: my tm5402hd will not clear some channels that my tm nano oe does with the same "provider". I have tried scanning again but nothing change (both receivers pick up a good signal)... any idea what it can be? I have another question not related to previous one, are the tuners in the two receivers different? better or worse? I noticed that for a couple of frequency I can pick up a very good signal in my nano but not on my 5402...... is mytm5402hd on its last leg?
Many thanks
tempo123 (2nd February, 2016)
yes you are right about those "certain" movie channels, but they have good signal (the tm signal strenght scale tell me there is good signal) so I am not sure it could be the LNB, I have a 1m dish with quadLNB and all other 3 ports are fine just 1 is giving me grief....
Are you using one side of a shotgun cable or is it a single cable. The 5402 and bm7000 for that matter don't fair very well with shotgun and i also moved the single feed to one of the two inner ports on my quad lnb when i was using my tm
digger99 (7th February, 2016)
I found it was the horizontal band i was having bother with and moving the cable to the inner output solved the issue but i ended up replacing the lnb after about 6 months. The tuner on the 5402 is generally very sensitive making it very good so it may be a faulty box
