All DVB-S channels are blank even FTA
Results 1 to 5 of 5
    Apr 2013
    Default All Sly channels are blank even FTA
    Since few days all my Sly and FTA channels are blank. It has been daily gales and gusts, it appears Sly dish is misaligned. Attached are screen shots of both tuners.
    Am I right in thinking there is no signal. What are your suggestions to fix it?
    I have also added reception settings of both tuners: A and B.
    Many thanks.
    Last edited by zhlad; 1st February, 2016 at 10:30 PM. Reason: Added Tuner settings
    Apr 2013
    Any feedback guys? If you say dish has problem then I need to be at home day time to fix it.
    I start in dark to work and return in dark. I will have to wfh to sort this out. Cheers
    Sent from my GT-I9505 using Tapatalk
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Sounds like you've answered your own question, but the easiest and cheapest way to test your dish is to borrow a mates satellite box, any type will do even a legit sky box, attach to your dish and see if it picks up any FTA channels, if it doesn't then you know your dish is misaligned or the lnb/cable is damaged.
    Then it's either up a ladder tweaking your dish until you get a signal or pay some bloke to do the work for you.
  4. The Following 2 Users Say Thank You to martin035 For This Useful Post:
    DOUGALMCD (4th February, 2016), zhlad (5th February, 2016)
    Apr 2013
    I did check dish and didn't find any change in alignment. This weekend I will test signal using my friend's openbox S10. Thanks.
  6. #5
    digicon's Avatar
    Jul 2009
    you have Zero SNR which points to a dish alignment problem
