Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
  1. #16
    scotland clydebank
    told customer dealer only i would not risk it with skp900 phoned several locksmith in glasgow and they told me dealer only.
  2. #17
    Oct 2015
    i have tried to do range rover 2012 with original avdi , customer want to add key and he ended by lossing all keys , was night mare for me , then when i tried to add key AVDI GIVING ME NUMBER of keys 2323232424 , that was crazy , i will never add key for range rover , all key lost only.
  3. #18
    Siham's Avatar
    Jul 2014
    Quote Originally Posted by craino View Post
    what happened ?
    Solved ?
    ORiginal still working ?
    No thank , no HELP .
  4. #19
    Oct 2015
    Quote Originally Posted by Siham View Post
    what happened ?
    Solved ?
    original lost communication after i tried to add key , need to be hold hear steering coloum to work , customer has same issue with other key lost communication by itself , NO CLUE UNTIL NOW NOT EVEN DEALER CAN FIGURE OUT WHAT HAPPEND ,adding key to range rover is a big mistake even with original AVDI. car date switched from 2016 to 2009 , it was disaster.
  5. The Following 2 Users Say Thank You to craino For This Useful Post:
    instakeys (3rd February, 2016), Siham (3rd February, 2016)
  6. #20
    Siham's Avatar
    Jul 2014
    Sorry for newbie question but what is RFA ?
    Also anyone know if truecode work after JLR recent update?
    Regards!
  7. #21
    Oct 2015
    Quote Originally Posted by JoK View Post
    RFA flash data has been corrupted when you tried to add key that's why you have to hold at steering column to work.
    Dealer should no that, quite possible it will need new RFA if they cant flash it.
    JoK
    you are right , something wrong with RFA I CHECK THE CAR BY avdi and got error U0214:002F lost communication with remote function actuator
  8. #22
    Jul 2016
    hello i loss a key for range rover 2016 sport and have AVDI with Range Rover key program license but when i try to connect it show could not open ignition and could not ope steering colum
    any idea ort any help pls
  9. #23
    Oct 2013
    You are a brave man because you are trying this risky job.
    Did you contact AVDI support?
    If you lost all keys, you may have to unlock BCM and/or KVM first. Then program keys.
    Please keep us updated with your progress!! I'm very curious.
  10. #24
    If you use last update cant make have bug.
    In new uodate what coming will be solved.
    And normaly
    first must unoock kvm manualy.
    After that you can adapt.
    And not need to be brave to use avdi on this.
    Only need to be smart put power and folow instruction.
    To much peaople not folow instruction and not give power and after that Avdi is problem
  11. #25
    Jul 2016
    hello we check the kvm its not locked and still cant open ignition when try to adapt key ? does we have to do something for bcm ? may it be the 2016 car have another procedure to open ignition and enter the programing mode ??
  12. #26
    Oct 2012
    London
    What do you mean not locked? Every RFA module 2015-2016 has the software update applied. What software are you using and what model?
  13. #27
    How you chek is lockes or no?
    What device you use first to make key?
