Results 1 to 15 of 15
    Dec 2013
    Default Fvdi connection problem: interface not calibrated
    Hello mates
    My fvdi was working properly and suddenly stopped connecting to the carImageUploadedByTapatalk1454611884.464863.jpg
    Any one have a solution for it
    It is the full version with no time limitation
    From flyobd.com
    May 2012
    Rawalpindi, Pakistan
    Check the cables, connectors or re-install the software. Try to change the port latency to 1 or 16. If the problem persists then it needs to have the software be activated.
  3. The Following User Says Thank You to shadab For This Useful Post:
    Stelaras26 (6th June, 2019)
    gopelhu's Avatar
    EU
    Quote Originally Posted by chadysaliba View Post
    Hello mates
    From flyobd.com
    Is Your interface MX29GL256 flash empty or damaged.
    Pls contact me...
    Regards, G
    BUSCADOS's Avatar
    Rosario
    Default FVDI
    Quote Originally Posted by gopelhu View Post
    Pls contact me...
    Regards, G
    HELP PLEACE
    THANKS
    Nov 2012
    Czech
    Hello i have the same problem, can you help me with this please?
    Nov 2012
    Czech
    Anyone help pls...
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Bay another
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    Is it fvdi2015 or 2014?
  10. #9
    Nov 2012
    Czech
    Fvdi2015 ... seller try reflash on internet connection with teamviewer but was still same... after all he send me new unit with red softdog... now i waiting for recieved
  11. #10
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    Must be a good seller if he did send you another unit...
    Try contacting gopelhu..He is very good at these fvdi!
  12. #11
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    A really goooooood Seller....
  13. The Following User Says Thank You to figani For This Useful Post:
    Stelaras26 (7th June, 2018)
  14. #12
    Aug 2018
    Deutschland
    Hello..
    I`m new here I have the FVDI V2015 V9.0 with red Softdog from FVDIOBD.com
    they all Program only Porsche not...
    with me these two popup windows go on ..
    I hope you can help me.
  15. #13
    alex_r_2001's Avatar
    New Jersey ,, USA
    Hey I just had that device not calibrated error.. all I did is went to the patch folder in abrites files... from there I installed the 64x packages and everything is fine now.. it's worth a try..
  16. #14
    Please I have fvdi with soft dog red fly two thousand fifteen serial both the soft dog ND the interface show green light no blinking I think.i need fw wf dB file to.progrm offline NY help please thx in previous
    Sent from my E6683 using Tapatalk
  17. #15
    Oct 2019
    Try to install another FVDI software version. It happened with me before with FVDI 2015.
