Results 1 to 15 of 16
    Sep 2015
    Default Corsa D Magneti Marelli 95320 EEPROM dump. advice on how to virginize or find ECU PIN
    Hi Guys i was hoping someone might kind enough to tell me how to virginize this EEPROM dump from Corsa D 2008 MJD 6O3 ECU?
    Or if someone code extract the pin?
    Thanks in advance
    Last edited by markpowell35; 5th February, 2016 at 05:35 PM. Reason: Forgot attachment :)
    Oct 2015
    try reset with 3963
  3. The Following 3 Users Say Thank You to rokibar For This Useful Post:
    7jjlle (24th January, 2017), Abro RU (14th February, 2016), romaiz96 (6th May, 2019)
    Sep 2015
    wow that was fast thanks ? is there a way you figured that out? i mean i know it's in plain text as a 5digit pin in the dump but how do you know it's them 4?
    i only ask because i gotta solder it back to the board before i can test that pin?
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    Opel pass code four numbers! not exist five! use software , code is immo Box or Ecu
    ..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
    Mar 2016
    Спасибо очень помогло
    kiszka's Avatar
    kiszka's Avatar
    Mar 2019
    hi
    can anybody help me aswell please i also have a corsa d 57plate 1.3 and need the security pin code from 95320 eeprom dump
    help will be very much appreciated
  10. #9
    Nov 2016
    @romaiz96 pin - 6048
  11. The Following User Says Thank You to Stopro92 For This Useful Post:
  12. #10
    Mar 2019
    thanks @stopro92 much appreciated
    just curious did you use softwares that calculated the pin or did you work it out? im just curious don't want to make it sound offending
    thanks again
  13. #11
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by romaiz96 View Post
    thanks again
    open eeprom file ..... and your eyes...... and you find the answer......
  14. #12
    Mar 2019
    yes i was doing that for the last 2 hours using hex editor but didnt know what line the pin code was in as i didnt want to guess and block any modules
    but thanks anyways much appreciated
  15. #13
    bank's Avatar
    Feb 2017
    Ukraine
    0x0f3-0x0f7
  16. The Following 3 Users Say Thank You to bank For This Useful Post:
    maliomladinac (11th July, 2023), obd.tech (28th October, 2019), RUSLAUTOEL (15th August, 2019)
  17. #14
    Dec 2019
    Hello, can You advice on this dump? Have 3 digits at first glance.
    1.3 95320
  18. #15
    Bllinda's Avatar
    Baltic
    https:/ /www.digital-kaos.co.uk/forums/showthread.php/817446-Corsa-D-Magneti-Marelli-95320-PIN?p=3837997&viewfull=1#post3837997
    today
    A topic that interests me
  19. The Following User Says Thank You to Bllinda For This Useful Post:
    CODEREADER (19th December, 2020)
