Dacia Lodgy 985103219R-C continental A2C80613210
Results 1 to 6 of 6
    Jun 2010
    MOLDOVA
    Default Dacia Lodgy 985103219R-C continental A2C80613210
    Hello,
    i have Dacia Lodgy , with airbag problem. Maybe someone have got files from block like this (85103219R-C continental A2C80613210) for compare.... Files can be with crash data...
    Thank you
    Dec 2009
    Romania
    Maybe this can help you!A2C80613210_985103219R_SPC960P50L3
    Jun 2010
    MOLDOVA
    thise is vith crash or clear ?
    i tholved thanks for all!!!
    castin's Avatar
    Oct 2015
    Poland
    I hawe the same unit from Dacia Dokker and lost org flash (data and code). Please, share orginall dump, but no in *.mot format. Only 512kb code_flash and 64kb data flash. Thanx.
    Dec 2009
    Romania
    Try this complete dump!After that I clear crash but I need your VIN car!Use Smok,New UPA or other programmer!
  6. The Following User Says Thank You to chiorbeq For This Useful Post:
    castin (28th April, 2017)
  7. #6
    castin's Avatar
    Oct 2015
    Poland
    Quote Originally Posted by chiorbeq View Post
    Ok, im try and reply.
    Update:
    Dump not work, need another version. Im load code_flash, then read and compare - file is the same, so programmer is ok.
    This is my PCB unit:
