this file cannot open
pass and off file please
hi friends, can you first check is this read corectly and if you can do immo off on this
File is corrupted or incorrectly read...
Non ut edam vivo, sed ut vivam edo.
try was with minipro but he dont read id of chip. I must see what is problem. Thanks
Maybe try bootmode? For Infineon C167 processors in Sirius 32 there are two types of connection to the Boot mode. Where on the marking in the LM - it is enough to connect through the resistor with 28 or 104 feet on the ground.Where RM requires a revision on the board ... you need to give a reset signal to the 44th leg flash from the 140th leg infineon, and not from the 141st as in the operating mode.
superpro sp500 is good solution and volta for immo off.tested work 100%
Money is not everything . . . when you have enough ! ...
MOBILTRONIC (19th January, 2020)
i was try with minipro, this is second ecu that a cant read corectly 29f200. I will try with new flash tomorow to see is this problem in minipro or in me. Maybe i dont clean flash enought. in any case thanks again
i try with new flash and its working. Can you give me immo off file to write and try with new flash on car. thanks
For correct work need original file.
make verify id on. this maybe solve your problems (bad id = bad read)
i have this programer too, working fine with this type flash, but wery important is GOOOOOOOOOOOOD CLEAN PADS i brush pads with sandpaper 1500-2000 grid.
paper lay on table and with flash brushing
Sometimes help me little press with finger on flash by reading writing. ewerithing must be good with verify.
BR
My English is little bit bad, but day after day is better. Like my experiences https://www.youtube.com/channel/UCdT...bx2Pc7WI4pWUWA
My help not for free, press THANKS and REP, for make me HAPPY
im not using passwords, my work is for this forum and members free
i try with sandpaper but still not working, and in adapter i broke one leg from chip. i try 239f400 from another ecu and evrerything is ok from id and reading. Like is someting wrong with this flash
