Results 1 to 15 of 15
    Mar 2012
    Default Ford focus c-max need DPF OFF
    I need dpf off in ford focus c-max.
    I tried with switches but car still can only 3000rpm max.
    Original file edc16c34 sw:1037396911 FORD-1037396911.rar
    Regards and thank in advance
    mihaiservice's Avatar
    Dec 2009
    http://www.quick-tuning.com
    if car are in limp mode with your dpf off file also must store some dtc,wich one are stored in ecu ?
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
    Mar 2012
    Thanks mihaiservice for reply,
    I check errors on the weekend because it is the car my brother in law
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    disconnect ECU Dpf ... send error U......
    ..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
    soundnavigator's Avatar
    Sep 2010
    Post your DPF OFF file for check. If all OK ... I have one idea. I have the same problem on Mazda 3 1.6 D ... really is the same.
    BR
    All full worked manual solutions - FAP/DPF OFF, Adblue/SCR OFF, EGR OFF, TVA OFF, SWIRL OFF, O2/Lambda OFF, DTC OFF and etc
    Our database available for download 24/7 on EVC server for all legal WinOLS users
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    LIMP should be not possible without DTC, someone must touched table.
    Did u compare file with other orginal to be sure ?
    All brand FileService - Custom - remapping company
    POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
    | Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
    Mar 2012
    hi,
    thanks everyone for your interest in my problem.
    This is my dpf off file WinOLS (Ford - 396911).rar
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    Your solution is not fully, and for me bad.
    Make try with only second byte - Restore first and last one.
    I think you copy solution from somewhere and don't checked it correctly
    Sep 2010
    The switches is right, but solution not full. With original software the car is in limp mode ... at first time ?
    Mar 2012
    yes, car was on limp mode before dpf off
    CustomCars
    tomorrow i try with only second byte,
    i dont copy solution i read about on ecuedit forum and i manualy change my original file
  11. #11
    Sep 2010
    OK, the car is in limp mode becouse have stored DTC for DPF ... if you make reset and delete it ... at first time have limp mode ?
    I have the same problem on Mazda 3 1.6D. With full DPF OFF no errors and the car still in limp mode. When changed glow plugs ... all was ok.
    If the problems is the same, need to change glow plugs for test or some special correction in software.
  12. The Following User Says Thank You to soundnavigator For This Useful Post:
    sppeedy (28th February, 2016)
  13. #12
    Mar 2012
    Hello,
    on the weekend i did not read errors
    because brother in law was busy.
    I have a question whether my original file is correct, because it was read with mpps. On another forum I found a file with the ECU with the same SW.
    And this file is different from mine.
    This is the file:
    https://mega.nz/#!55xT3CbS!0TlDQDTIV...Pirf2khxwZDZJk
  14. #13
    Sep 2010
    The file is OK as OBD read.
  15. #14
    Sep 2009
    friend, you have problem p1187 read by bdm send e2p.
  16. #15
    Mar 2012
    Thanks all for helping in my thread,
    The problem was with glow plugs.
    After replace all is ok
